Aleksander44
Pridruen/-a: Čet Avg 2020 17:55 Prispevkov: 286 Kraj: Grosuplje
Objavljeno: Tor Nov 09, 2021 20:57 Naslov sporočila: Internetni radio v Dolby 5.1 |
PosluŔanje internetnega radia v stereo tehniki ali katerem od upmikserjev AVR-ja (straight, 2 ch stereo, 7ch stereo, auto) na AVR-ju je nekako zaduŔeno. Morda se uho razvadi prostorskega zvoka.
Će internetni radio posluÅ”am preko Shield TV streamerja in le ta izvaja upmix na Dolby 5.1 se zvok odpre, basi pridejo do izraza. Internetni radio se posluÅ”a v pravem prostorskem naĆØinu.
Nazadnje urejal/a Aleksander44 Sre Nov 10, 2021 09:42; skupaj popravljeno 1 krat |
Pridruen/-a: Pet Mar 2011 15:36 Prispevkov: 1007 Kraj: Ljubljana
Objavljeno: Tor Nov 09, 2021 21:47 Naslov sporočila: |
Vse kar (na AVRju) ni analog bypass, direct analog itd...je procesirano. Torej zvok kot si ga nastavil oz. je prednastavljen. VkljuĆØno z LFE. VkljuĆØno z delayi surround zvoĆØnikov. _________________ My leader told me to jump in the river. .The river was deep and the weather was winter. .After a sailer very kindly saved me, my leader told me, you'd better take it easy. .I took it so easy my leader called me lazy! |
Aleksander44
Objavljeno: Tor Nov 09, 2021 22:21 Naslov sporočila: |
When STRAIGHT is pressed and the straight decode mode is enabled, the unit produces stereo sound from the front speakers for 2-channel sources such as CDs, and produces unprocessed multichannel sounds for multichannel sources.
Ne vem, ĆØe se ĆØisto razumeva. HoĆØem reĆØi, da mi noben naĆØin, vkljuĆØno straight ne zveni tako dobro, kot eksterno procesiran v 5.1. Barvna vs. ĆØrno bela TV. |
Objavljeno: Tor Nov 09, 2021 22:47 Naslov sporočila: |
Ja potem ti pa tista maŔinca napumpa note. Kater reciever pa imaŔ da ti tako "tanko" igra? _________________ My leader told me to jump in the river. .The river was deep and the weather was winter. .After a sailer very kindly saved me, my leader told me, you'd better take it easy. .I took it so easy my leader called me lazy! |
Aleksander44
Objavljeno: Sre Nov 10, 2021 07:04 Naslov sporočila: |
Dva zvoĆØnika ne moreta tako napolniti prostora kot jih osem v 5.1 formatu. Yamaha Aventage. |
sullly
Objavljeno: Sre Nov 10, 2021 09:50 Naslov sporočila: |
Aleksander44 je napisal/a: | Dva zvoĆØnika ne moreta tako napolniti prostora kot jih osem v 5.1 formatu. Yamaha Aventage. |
Seveda imaÅ” prav.
To sem imel priliko sliŔati pri nekaterih frendih z AV risiverji. Preklop na stereo je bil netto netto izpod surrounda.
Drži kot pribito, a zakaj?
Drži tudi, da je tisti stereo zelo slab napram namenskemu stereu - se sliŔi dosti slabŔe kot je stereo sposoben. Preklop na stereo ti samo razgali vso bedo sistema.
Tukaj bi lahko konĆØal a ker sem danes dobre volje nadaljujem..
Po vrsti:
Za tisoĆØaka dobiÅ” 7.2 naprimer 5015 od Marantza s 180W po kanalu.
NajcenejÅ”i 180W pravi stereo ojaĆØevalci zaĆØnejo pri najmanj dvojni ceni.
Pomeni vsaj faktor x5 v ceni na kanal, ker AV risiverji imajo Å”e procesorje notri, pa tuner, pa Å”e sto drugih funkcij vkljuĆØno z ekvalizacijami itd
Isto zvoĆØniki projektirani za surround ne morejo tekmovati v stereo naĆØinu s stereo Å”ampion zvoĆØniki. Suround potrebuje centralni kanal - stereo dober zvoĆØnik zmore centralno sceno brez težav. Ne samo to, gre scena od izven levega zvoĆØnika ĆØez celo steno preko desnega zvoĆØnika in konĆØa izven - pa v globino gre tako kot suround ne zmore.
Res pa ti stereo ne more odzadaj predvajati glasbe.
Tisti ko pa majo dost denarja, si pa lahko omislijo mono konĆØne stopnje, loĆØene procesorje in loĆØene predojaĆØevalnike in kupijo temu primerno zvoĆØnike zvoĆØnike, hebat ga, nismo Å”e tam. Menda se lahko downlowda (od 2L) prave, nativne, petkanalne posnetke orkestrov in znalci prisegajo na to. Nisem Å”e sliÅ”al a rad verjamem.
Treba je upoÅ”tevati da je scena samo en vidik kakovosti - drugi so zelo zaguljeni kot je mikrodinamika, resolucija, koherentnost in v takem redu naprej - vse stvari ki enega povpreĆØnega uporabnika surounda en klinc brigajo. Zato so lahko suroundi poceni, ma ĆØe gremo primerjat s stereo, potem je potrebno biti poÅ”ten in ne vleĆØi na plano samo en vidik.
Res je tudi, da vrhunski stereo s pravimi stereo posnetki (tipa Blumlein) zmore tudi holografijo - kar v petkanalni reprodukciji ne obstaja niti kot pravljica.
Je pa prav reĆØi, da smo lahko sreĆØni, da obstaja suround - ene vrste sindikalni hifi - ni potrebno veliko potroÅ”iti za obĆØutek zadovoljstva.
Nazadnje urejal/a sullly Sre Nov 10, 2021 10:53; skupaj popravljeno 1 krat |
sullly
Objavljeno: Sre Nov 10, 2021 10:46 Naslov sporočila: |
ZvoĆØnik=zvoĆØnik, stereo (blumlein)=stereo (fake iz mix pulta),high end (dejanski) = high end (iz reklamnega deplianta), watt=watt (recimo direkt udarec boksarja ki stoji na prstih ene noge in isti udarec ko se opre na obe nogi), kabel=kabel...
Ja, je isto, a samo verbalno.
Obstaja zabaven naĆØin informiranja - postaviÅ” trditev za katero bi rad izvedel zakaj ne drži. Ok, ĆØe ne gre drugaĆØe.. |
Objavljeno: Sre Nov 10, 2021 10:55 Naslov sporočila: |
Osnovni problem bo verjetno to da je internetni radio slabe kvalitete. PaĆØ so pogosto AAC z nizkimi bitrate-i.
Shield TV s svojim procesiranjem oĆØitno bolje zamaskira.
Meni upmixan surround na AV zveni kot bi imel prižgani dve televiziji, ki nista usklajeni. Skratka kot koncert v areni Stožice (kar je drek).
Prve digitalne klaviature (recimo Roland D-50) so tudi imele ogromno reverba, da se ni toliko sliŔalo artefaktov. |
Aleksander44
Objavljeno: Sre Nov 10, 2021 13:01 Naslov sporočila: |
LightBit je napisal/a: | Shield TV s svojim procesiranjem oĆØitno bolje zamaskira.
Meni upmixan surround na AV zveni kot bi imel prižgani dve televiziji, ki nista usklajeni. Skratka kot koncert v areni Stožice (kar je drek).. |
Ja, opis je mord malo grob, ampak blizu. Iz Nvidie pride drugaĆØen. VeĆØina je 128 kbps. |
Objavljeno: Sre Nov 10, 2021 18:24 Naslov sporočila: |
Zato imam pa HT brez centra, main zvoĆØnika odÅ”pilata center fantastiĆØno. Vklop nekega centra v budgetu bi bil popopn nesmisel in sem prperiĆØan da tudi downgrade sistema. _________________ My leader told me to jump in the river. .The river was deep and the weather was winter. .After a sailer very kindly saved me, my leader told me, you'd better take it easy. .I took it so easy my leader called me lazy! |
Qobuz pri nas
EMMA SQ Finale - April 2024
Glava gramofona? Kaj kupiti?
