Polnilne baterije + polnilci
kumer
Prispevkov: 948
PrispevekObjavljeno: Čet Okt 11, 2012 14:06    Naslov sporočila: Odgovori s citatom
kaj pa primerjava med eneloop in eneloop xx, se splača vzet xx varianto
glede polnilca...ali govorimo o tem:
http://www.amazon.co.uk/MH-C801D-Charger-Independent-Charging-Circuits/dp/B003OU51LG/ref=sr_1_1?ie=UTF8&qid=1349956923&sr=8-1
ali tem:
http://www.amazon.co.uk/Maha-MH-C801D-Independant-Intelligent-Batteries/dp/B003L7AWQG/ref=sr_1_2?ie=UTF8&qid=1349956923&sr=8-2
v čem je razlika, pri prvem ne piše maha ampak powerex
oba pa imata zelo malo ocen na amazonu, ponavadi ima "popularna" roba precej več ocen...?
Hvala
Prispevkov: 891
PrispevekObjavljeno: Čet Okt 11, 2012 23:43    Naslov sporočila: Odgovori s citatom
Hmm, zdaj pa si me dobil... Gledal sem oba polnilca preko linkov, ki si ju dal tu na voljo in resnično ni videti razlik. Po mojem gre za eno in isto stvar, le da je Powerex del Mahe, glej spodaj citat (Corporate profile) z njihove strani!
Na mojem piše samo Maha MH-C801D Eight cell 1-hour aa/aaa batery charger... Zraven je polnilec Maha AC adapter model MHS-CX1802000S... Če si kje iz LJ ali okolice, ti ga lahko dam na probo, imam namreč dva....
Corporate Profile
Founded in 1993, Maha Energy Corporation is a global leader specializing in the design, manufacturing, and distribution of battery and charging technology for various industrial and consumer sectors. With state-of-the-art research labs and production facilities in Asia, and sales & marketing offices in North America and Europe, Maha creates a global service network for both standard and custom-designed applications.
In addition to PowerEx brand products, a significant percentage of Maha Energy's revenue is generated from OEM & custom manufacturing businesses. Today, Maha manufactures millions of batteries and chargers sold under OEM and private brands for leading corporations in all industrial sectors. Maha's custom battery program also won key contracts from government and military agencies.
Prispevkov: 891
PrispevekObjavljeno: Čet Okt 11, 2012 23:57    Naslov sporočila: Odgovori s citatom
Evo tole sem ti našel na internetu; gredo po vrsti (od najboljšega navzdol), predvsem so prisotne štiri firme: Ansmann, Maha PowerEx, Sanyo in LaCrosse (za to zadnjo še nisem slišal)... Po izboru čez lužo...
The Best Battery Chargers 2012:
1. Eneloop Pros (or Sanyo XX Battery Powered By Eneloop)
2. LaCrosse Technology BC-1000 Alpha Battery Charger
3. PowerEx MH-C9000 WizardOne Charger-Analyzer
4. Ansmann Deluxe “Energy 16″ Charger
5. Ansmann Deluxe “Energy 8″ Charger
6. Maha PowerEx “Ultimate Professional” Charger
kumer
Prispevkov: 948
PrispevekObjavljeno: Pet Okt 12, 2012 09:17    Naslov sporočila: Odgovori s citatom
hvala, ali morda veste, če obstajajo kakšni forumi posvečeni tej temi
- polnilne baterije
- polnilci
Hvala
twom
Prispevkov: 301
PrispevekObjavljeno: Pet Okt 12, 2012 13:04    Naslov sporočila: Odgovori s citatom
kumer je napisal/a:
- polnilne baterije
- polnilci
http://forum.modelarji.com/
Prispevkov: 891
PrispevekObjavljeno: Sob Okt 13, 2012 00:59    Naslov sporočila: Odgovori s citatom
Tudi na fotografskih forumih se najde kaka tema - problem, ki pa nastane, je klasičen - preveč strokovnjakov na kupu - vsi poznavalci in potem ne veš več kaj in kako...
kumer
Prispevkov: 948
PrispevekObjavljeno: Pon Maj 06, 2013 15:03    Naslov sporočila: Odgovori s citatom
nakaj časa je že preteklo odkar smo se nazadnje pogovarjali o polnilcih, baterijah...
ali so danes še vedno aktualne enake baterije in polnilci kot oktobra lansko leto
torej kaj priporočate za polnjenje AAA in AA baterij, katere baterije?
Iščem bolj kvalitetne in zmogljive variante, ne ravno najdražje, ne pa tudi poceni sr***, torej nekaj kar bom lahko uporabljal dalj časa....
Hvala
Prispevkov: 891
PrispevekObjavljeno: Pon Maj 06, 2013 23:02    Naslov sporočila: Odgovori s citatom
V globalu da - ni nekih novih baterij, ki bi vse postavile na glavo...
Prispevkov: 1380
PrispevekObjavljeno: Tor Maj 07, 2013 07:34    Naslov sporočila: Odgovori s citatom
Sam uporabljam Sanyo Eneloop in so zakon (vsaj kar se tiče AA akkujev). V modelarstvu načeloma vsi uporabljamo Li-Po celice, ki pa so čisto drug svet.
Matt
3000ES
Prispevkov: 228
PrispevekObjavljeno: Tor Maj 07, 2013 09:22    Naslov sporočila: Odgovori s citatom
Vinylfan je napisal/a:
... ni nekih novih baterij, ki bi vse postavile na glavo...
Drži.
Sam se še vedno držim Eneloop-ov. Že od kar so prišli ven, in še vedno imam tudi prve kupljene. Nikakršnih težav.
kumer
Prispevkov: 948
PrispevekObjavljeno: Tor Maj 07, 2013 14:10    Naslov sporočila: Odgovori s citatom
lahko morda bolj točno poveste kateri model eneloopov priporočate, jih je več....
kaj pa glede polnilca, iščem nekaj večjega, torej polnilec, ki polni cca 8+ kom hkrati ter seveda kvalitetno...
hvala
Prispevkov: 1380
PrispevekObjavljeno: Tor Maj 07, 2013 19:36    Naslov sporočila: Odgovori s citatom
V kolikor bi želeli polnilec uporabljati še za kaj drugega si kupite npr. tole
Gre za pametni polnilec na katerega lahko priključite vse mogoče akumulatorje - polnjenje z avtomatskim načinom oz. bolj pametna varianta manual. Lahko nastavite polnilni tok in to je to. Izdelate npr neko držalo za 8 akumulatorjev (dobite v elektro trgovinah) in vse priključite na polnilec, izberite tok polnjenja in to je to. Pri AA baterijah ni potrebno pretiravat s polnilnim tokom. Pri tekmovalnih celicah polnimu tudi s 5 A in več.
S takim polnilcem lahko tudi ugotavljate kater akumulator je zanič (pregrevanje), prav tako se sam ustavi ko doseže kapaciteto - tako vidite dejansko stanje akumulatorja.
Matt
kumer
Prispevkov: 948
PrispevekObjavljeno: Tor Maj 07, 2013 20:00    Naslov sporočila: Odgovori s citatom
hvala za nasvet, vendar je to preveč kompleksno za mene, nisem elektronik ipd...
iščem samo dober polnilec
hvala
Prispevkov: 1380
PrispevekObjavljeno: Tor Maj 07, 2013 20:10    Naslov sporočila: Odgovori s citatom
Potem je pa vseeno, če kupite tistega, ki je v kompletu. Kupite dva seta po 4 akkujev (zraven sta polnilca), tako lahko naenkrat polnite 8 komadov (2 polnilca) in to je to, brez komplikacij. Standardne so bele Eneloop, lahko pa vzamete tačrne z nekaj večjo kapaciteto. Prednost teh akumulatorjev je predvsem to, da zelo počasi izgubljajo kapaciteto, če se ne uporabljajo.
Jaz imam bele Eneloop in jih uporabljam v Tascam prenosnem snemalniku.
Matt
3000ES
Prispevkov: 228
PrispevekObjavljeno: Sre Maj 08, 2013 09:26    Naslov sporočila: Odgovori s citatom
kumer je napisal/a:
Kot je že trancedeejay povedal, obstajajo le črne in bele, ni jih več.
Meni bele (1900 mAh) zadostujejo. Lahko pa mirne duše uprabiš tudi črne (2500 mAh). Ne moreš zgrešiti.
Zgolj za ilustracijo: uporabljam jih v devetih daljincih, treh fotoaparatih in še celem kupu naprav. In polnilci, ki jih dobiš tudi v kompletu s štirimi Eneloopi zadostujejo. Zunanji dve poziciji imata funkcijo "quick charge", če želiš na hitro napolniti dva akumulatorja.
Navadnih baterij nisem videl že od pojava Eneloopa na trgu. Mogoče ne ravno deset let, zagotovo pa krepko čez pet.
Bo to dovolj podatkov ?
Stran 2 od 3
