4K TV
Pojdi na stran Prejšnja  1, 2, 3 ... 13, 14, 15, 16  Naslednja
Zuluf
Prispevkov: 677
Kraj: bunga bunga
PrispevekObjavljeno: Sre Feb 11, 2015 15:11    Naslov sporočila: Odgovori s citatom
cink je napisal/a:
svi ovde glupi samo trol Zuluf pametan press (heh moral sem prekršiti moje pravilo).
Lej kaj pišejo pravi stručnjaki za samsung 8500:
The [Smart LED] “Standard” and “High” positions obscured shadow detail and altered gamma too much for our liking, leaving [Smart LED] “Low” as our preferred option. Some luminance fluctuations remained visible during challenging low-APL scenes (for example as Batman emerges from the shadows to meet Catwoman in The Dark Knight Rises – timecode 01:10:04), but they were infrequent and worth the compromise to improve black-level response.
O tem sem že pisal na svoji 7000, sicer pri eni drugi funkciji, ampak pri 8500 je to treb prebavit, ker ips panel pa črna ne gresta skupaj.
IPS paneli so slabši za kontraste:
After pegging peak luminance to our usual target of 120 cd/m2, the native black level (i.e. with [Smart LED] disabled) on our Samsung UE55HU8500 review unit measured 0.069 cd/m2 on both a full-field video black signal with auto-dimming defeated by pressing the [INFO] button, and a 4×4 ANSI checkerboard pattern. While higher than the circa-0.05 cd/m2 we’ve seen on Samsung’s SPVA panels in recent years, the slightly brighter blacks were perhaps understandable given the complicated warping process needed to produce a curved screen, and in any case bettered every IPS LCD television we’ve reviewed.
Čeprav ima boljši bfi kot sony se dogajajo zatikanja:
The whole picture would stutter, which might be accompanied by some tearing/ combing. We observed these artefacts too while watching live football, e.g. when the camera cut from a close-up of the manager’s face back to the field.
Jaz mislim, da si reviewerji vse to izmišljajo, ker LCD je bulletproof, sploh 4k. To pa lahko ugotovimo že če samo stopimo v trgovino brez da preverimo nastavitve posameznih tv-jev in komentiramo kako kater tv dobro procesira signal in kako ga kateri ne. Sploh pa se vidi kvaliteta barv in kontrastov, ker tv-ji niso našponani do konca.
Pojdi v trgovino in si vzemi daljinec pa preveri nastavitev za nastavitvijo, ker doma boš itak počel to.
Če bi še enkrat kupoval bi vzel plazmo ali pa lcd do 400 eur. Več od tega namreč niso vredni. No lej samsung se pa dobr šalta, res hitra zadeva tudi smart tv. Dost hitrej kot lg, ki sem ga probal včeraj. streama kot šus... Slika pa .... to ni plazma, niti blizu.
Tale članek je kar ok:
http://www.cnet.com/news/black-frame-insertion-busting-blur-from-oculus-to-lcd-tvs/
The HU8550 motion resolution enhancement tech includes adjustable motion compensation/estimation (aka Auto Motion Plus) as well as black-frame insertion (aka LED Clear Motion). I appreciate Samsung providing a custom configuration for these controls that can apply blur reduction to video sources while disabling judder reduction for more faithful, un-smoothed, film reproduction. One benefit of enabling the LED Clear Motion (LCM) feature is that it can enhance image clarity of film-sourced video without introducing unnatural smoothing to on-screen motion. While very effective, LCM introduced flicker into the picture that I found annoying enough to finally disable the feature.
Zveni znano?
Zuluf
Prispevkov: 677
Kraj: bunga bunga
PrispevekObjavljeno: Čet Feb 12, 2015 11:04    Naslov sporočila: Odgovori s citatom
Cenejše plazme nisem našel:
Motion Resolution
During the review, the LG 50PK590 produced excellent motion clarity which was visibly better than any LCD TV (100hz/200hz assisted or not). The test charts on the FPD Benchmark disc allow us to review motion resolution in a more objective manner, but because Plasma displays have naturally excellent motion, it can often be quite difficult to give exact numbers while looking at the chart by eye (compare this to the performance of most LCD TVs, where the shortcomings are blatant). The LG 50PK590 displayed around 900-1000 clear lines with the scrolling chart, which is an absolutely excellent result – just what we’d expect from a Plasma HDTV.
Za primerjavo najboljši lcd zmore tretjino resolucije gibanja "najslabše" plazme. Razen na tem forumu, kjer imamo nadnaravne lcd-je z izjemnimi sposobnostmi resolucije gibanja.
Kolikor gledam tudi oled ni nič boljši od lcd-jev glede resolucije gibanja.
PrispevekObjavljeno: Čet Feb 12, 2015 12:26    Naslov sporočila: Odgovori s citatom
Za kabelsko imam Telemachov Cisco router in D3 vmesnik z HDMI izhodom. Televizor je 6 let star LG LCD televizor z frekvenco okoli 60Hz, pomeni, da je frekvenca prenizka.
HDMI kabel je ranga 40EUR iz Technotopa in je malenkost izboljšal sliko napram TVju priloženemu kablu.
Par mesecev nazaj sem sklenil, da bom power lajšto lastne izdelave ulaufal "zapekel" kar na TVju.
Vse naprave sem pretaknil iz Legrand power lajšte v svojo lajšto.
Sprememb nisem pričakoval, sploh ne radikalnih.
Slika je takoj postala čistejša in pravilnejša, na nivoju prejšnje HD slike(!), na HD kanalih pa je slika postala dobesedno popolna in tako neutrujajoča, brez najmanjših sledi artefaktov, da čeprav gledam TV bolj malo, sem jo gledal par dni.
Na nivoju novih LCD TVjev z več 100Hz frekvenco osveževanja.
Lajšta je nato romala k prijatelju, ki nima HD routerja in D3 vmesnika, pri njem vidnih razlik ni bilo.
Če bi mi kdo rekel, da je to možno, ne vem če bi mu verjel.
Zadevo sem nato predebatiral z prijatelji iz USA, eksperti za izdelavo audio kablov, našli smo neko domnevo, ker pa je samo domneva, je ne bom razlagal.
Seveda sem se odločil, da bom naredil še napajalni kabel za TV, identičen tistemu, ki je na power lajšti.
Pri kablu je slika prvo "šla na slabše"..
Čim sem ga priklopil, so barve postale kričeče, po kakem dnevu so postale "normalne" nato pa se je slika iz dneva v dan izboljševala, enako zvok TVja.
Odkar se je kabel "zapekel", je slika še malenkost boljša.
Prispevkov: 6263
PrispevekObjavljeno: Pet Feb 13, 2015 11:51    Naslov sporočila: Odgovori s citatom
Za vse nejeverne Tomažeke sem že nekajkrat predlagal, da si na TV dobesedno ogledajo ogromne razlike med napajalnimi kabli.
Me prav zanima, koliko jih bo še trdilo, da napajalni kabel ne vpliva ...
canyonn
Prispevkov: 642
Kraj: kanal
PrispevekObjavljeno: Pet Feb 13, 2015 13:02    Naslov sporočila: Odgovori s citatom
10 K high speed .............
https://vimeo.com/119343870
PrispevekObjavljeno: Pet Feb 13, 2015 13:24    Naslov sporočila: Odgovori s citatom
Se strinjam, 200%...Še večja razlika v zvoku sistema je bila, ko sem na PC, ki poganja Music server eno nadstropje nižje priklopil dober napajalni kabel.
Tudi tu sem hotel frišen kabel samo ulaufat in seveda se mi je PC zdel za to najprimernejši, ker naj bi ne vplival na zvok, če samo futra music server. In dobesedno padel dol, ko sem po menjavi nič "hudega sluteč" šel poslušat glasbo, ker dejansko nisem pričakoval čisto nič..
Končalo se je tako, da sem potem menjaval različne kable na PCju, da sem tako dobil res odličen zvok na sistemu..
Če sem prav razumel Stormsonica, ki se definitivno na forumu praktično še najbolj spozna na digitalno-analogno pretvorbo, si med pretvorbo sledijo različni analogni in digitalni procesi in tako bi kabli definitivno lahko vplivali na analogne procese med pretvorbo, če že na digitalne ne .
PrispevekObjavljeno: Pet Feb 13, 2015 23:20    Naslov sporočila: Odgovori s citatom
Ambasador, kje si videl 4K Oled?
PrispevekObjavljeno: Pet Feb 13, 2015 23:56    Naslov sporočila: Odgovori s citatom
To je tehnologija dvb-t2 na prizemni način v 2160p. Free to air. Smile
https://www.youtube.com/watch?v=fbTv0EulNnI
Zuluf
Prispevkov: 677
Kraj: bunga bunga
PrispevekObjavljeno: Ned Feb 22, 2015 15:31    Naslov sporočila: Odgovori s citatom
Tako kmalu bo april, ko cene tvjev najbolj padejo. Vsaj tako pravijo da naj bi bilo zaradi novih modelov. Pa da tema ne zamre...
izbral sem eno sceno, kjer je beda lcdja nepopisno ocitna. Seveda je takih scen veliko, ampak tu je zaradi malostevilnih objektov in dosti svetlobe zadeva zelo ocitna. Upam, da premik kamere ni prehiter in je zadeva izkljucno posledica bede lcdja in ne 24fps. Meni se ne zdi prehitra, ampak mora en s plazmo preverit ali je posnetek pri njem jasen In zvezen.
no da ne bo kdo mislil, da je to edini posnetek, ker tega je v birdmanu ogromno. Samo vceraj sem ga gledal in bolj proti koncu je bil. Torej scena cca 1:50:30 v birdmanu 2014, ko birdman gleda skozi okno bolnice. Kamera se obrne najprej v desno in potem se nazaj. Ce pogledate najvisjo stavbo bo v tem kadru na lcdju zamegljena, kar nekaj dvojnikov bo okrog nje... z motion kontrolami se lahko znebimo dvojnikov, na dokaj mocnih nastavitvah. Zamegljenosti se povsem ne da odpraviti v vseh trenutkih. Ampak posledica je seveda SOE. Zdaj pa sonijasi posteno prosim, kako vidite neboticnik. Je cist ali utripa? Da vidimo ali je samo samsung zanic ali so vsi.
simonceli
Prispevkov: 204
Kraj: Komenda
PrispevekObjavljeno: Ned Feb 22, 2015 15:57    Naslov sporočila: Odgovori s citatom
Bi rade volje, vendar nimam tega filma na BluRayu.
PrispevekObjavljeno: Ned Feb 22, 2015 17:50    Naslov sporočila: Odgovori s citatom
Mam ta rip doma. To je scena, ko rece najprej F* U nato pa panning kamere desno in nato levo? Sem poskusil najprej na monitorju Dell U2412M in utripa kar zelo agresivno. Se nisem opazil nikoli tako. Potem sem poskusil na Sony-u in je 90% manj. Bi blo pa treba pogledat original BluRay in na klasicnem CRTu Smile.
Zuluf
Prispevkov: 677
Kraj: bunga bunga
PrispevekObjavljeno: Ned Feb 22, 2015 23:49    Naslov sporočila: Odgovori s citatom
simonceli je napisal/a:
ja potegni ga Very Happy
Sicer mas pa tusevo reklamo za ene ajdove struklje npr. Tam je tudi zelo ocitno, vendar bi tam znala bit hitrost gibanja problem. Na lcdju zadeva ni zvezna. Bolj so svetle scene bolj je opazno...
jaz na zalost opazim bistveno vecje podrobnosti kot je to in mi gre zadeva na k. Utripanje in zameglitve namrec.
Zuluf
Prispevkov: 677
Kraj: bunga bunga
PrispevekObjavljeno: Pon Feb 23, 2015 23:03    Naslov sporočila: Odgovori s citatom
http://www.rtings.com/info/motion-blur-tvs
Prav zanimivo je gledat kako so ocene motion blura napredovale v enem letu, ko so iz prodaje vrgli plazme. Kar naenkrat imajo lcdji ocene 9,5...
Prej pa od 5-7.
Primus
Pridružen/-a: Tor Okt 2008 11:03
Prispevkov: 38
PrispevekObjavljeno: Tor Feb 24, 2015 13:15    Naslov sporočila: Pansonic Viera 2015 Odgovori s citatom
http://news.panasonic.co.uk/pressreleases/mastering-the-magic-of-light-panasonic-s-2015-4k-uhd-led-viera-tv-line-up-delivers-the-directors-visions-in-your-living-room-1120533
https://www.avforums.com/news/panasonic-uk-european-tv-line-up-revealed.11219
https://www.avforums.com/news/panasonic-2015-4k-uhd-full-hd-tv-specs-and-photos.11223
Nazadnje urejal/a Primus Tor Feb 24, 2015 16:29; skupaj popravljeno 1 krat
Primus
Prispevkov: 38
PrispevekObjavljeno: Tor Feb 24, 2015 15:52    Naslov sporočila: 4K demo :) Odgovori s citatom
evo 4k demo Smile
http://youtu.be/XcFAXHLQeJw
Nazadnje urejal/a Primus Tor Feb 24, 2015 16:27; skupaj popravljeno 1 krat
Stran 14 od 16
