Zuluf
Objavljeno: Sob Dec 13, 2014 20:38 Naslov sporočila: |
| Ja pocen tole ni. Mal so pretiraval s ceno ampov. Dobre tri jurje so pasivni, tule se pa o ceni 6k govori.... |
Zuluf
Zuluf
nomad
Objavljeno: Pon Jan 12, 2015 14:56 Naslov sporočila: |
V lanski julijski številki HiFi Choice je na 81. strani članek Davida Viviana z naslovom Go with the pro? Članek se ukvarja z vprašanjem ali so pro zvočniki uporabni tudi za domače poslušanje. Avtor seveda ni na dolgo in na široko (in na prazno) teoretiziral kot smo bili priča na prejšnjih straneh te teme, temveč je vprašanje naslovil na dva izmed najbolj znanih proizvajalcev, ki sta uveljavljena tako v pro kot v home sektorju. Tole je par odlomkov iz članka:
| Citiram: | A loudspeaker is a loudspeaker, isn’t it? Should it really make a difference if it’s for use by a professional in a studio or an audiophile listening at home?
Do we imagine that the oxygen-starved summit of high fidelity ambition is to replicate as far as possible the ‘studio sound’ with its unerringly honest, warts ‘n’ all transparency, plaster-cracking volumes and heart-stopping dynamics? Or do we want a system that has been skillfully tailored to maximise musical enjoyment and communication?
To suggest this line of thinking to speaker manufacturers that produce distinct lines for recording studios and domestic living rooms – I’m thinking, in particular, of ATC and PMC – is a dangerous business.
ATC founder and boss Billy Woodman is emphatic: “A high fidelity loudspeaker is a high fidelity loudspeaker, whether or not it is for the professional or the audiophile. We do not differentiate between the two in any aspect of performance.”
PMC’s founder and boss Peter Thomas concurs. “We believe there is only one way to design a loudspeaker, be it for the professional or domestic market, and that is the right way,” he asserts. “Our speakers are designed so they are voiced the same for studios and the home, as there is only one ‘right sound’.”
Peter goes on to explain that the only things separating its pro and domestic models are aesthetic and functional. “Differences do exist between the two markets,” he continues, “but these are concerned with the shape of speaker, the look of the speaker and whether they are active or passive. Each market’s application influences these factors. The active design also allows drive unit protection to be built in to make the speaker extremely reliable and bomb proof. Reliability is a big issue for pro designs operating at high SPLs.”
Keeping it neutral
Anyone who’s visited a recording studio will have a fuller appreciation of what Peter means by this. “However, speaker designs have to enable successful use with a variety of different amplifiers. And we still provide the same voicing as our studio monitors to ensure an accurate reproduction of the music. We also produce wide dispersion designs for excellent imaging.”
ATC’s approach is no less single minded. As Woodman explains: “Our design philosophy has always been predicated upon the notion of ‘neutral fidelity’, which requires an almost fanatical dedication to the detail in the design and development of both loudspeaker drive units and complete loudspeaker systems.”
You can’t argue with that. Or the fact that both companies’ domestic speakers consistently get rave reviews. |
S podobnimi temami se ukvarja tudi avtor recenzije še enih zvočnikov iz nevtralne šole ki se uporabljajo tako za domače poslušanje kot za studio (ponovno so obe verziji identični, razlikujejo se samo po finišu), gre za Grimm LS 1. Tu je govora tako o razliki med »nevtralnim« in »muzikalnim« pristopom, članku J. Gordona Holta "Down With Flat!", predvsem pa so zanimivi komentarji poslušalcev in avtorja na koncu recenzije.
http://www.positive-feedback.com/Issue75/grimm_ls1.htm |
Pridružen/-a: Sre Feb 2011 19:52 Prispevkov: 6260 Kraj: Izola
Objavljeno: Pon Jan 12, 2015 19:39 Naslov sporočila: |
@nomad: ..ali so pro zvočniki uporabni tudi za domače poslušanje..
Ne vidim dileme. Če je komu všeč, si kupi kar hoče.
Saj v preteklosti ni bilo nič drugače: profesionalci so iz hobi Hi-Fi-ja 'posvojili' npr Yamaho NS10, avdiofili pa npr. BBC monitor LS 3/5a. Če omenim najbolj razvpite primere.
Na načelni ravni, po mojem tudi ni dileme: zvok v originalu je en sam. Vsi zvočniki bi 'morali' težiti k 'isti resnici'. Ravno tako bi morali vsi zvočniki vključno z monitorji enako dobro reproducirati veliki orkester, klavir, solo violino, kot tudi besne elektrificirane bende.
Mi se poraja vprašanje:
- ali studiji za klasično glasbo uporabljajo identične monitorje kot tisti za jazz ali dance, ali narodnjake?
Velika večina sodobne klasične glasbe je monitorirana na Bowers&Wilkins in če izbereš njihov top model ali enega iz istega legla, imaš izpolnjen glavni pogoj, da dobiš to, kar so v studiju poslušali. Isto lahko rečemo za vse druge monitorje.
Tudi za dobiti zvok iz koncerta v živo poljubnega benda je najpreprosteje kupiti identične zvočnike in na njih spustiti posnetke.
Osebno nisem veliki ljubitelj studijsko skrojenega zvoka, čeprav ga, glasbi na ljubo, tudi moram prebaviti. Pri čemer me prav nič ne briga ali se sliši kot na monitorje v času ko so snemali - itak je fake, pa popolnoma brezbrižno dodam še moj fake.
So mi bolj všeč 'terenski' posnetki, koherentni s čimmanj manipulacije. Kar se tiče mojega hobija, je to tisti del, kjer se trudim - temu prilagajam moj sistem. Kolikor pač zmorem in znam. _________________ Carpe Diem |
Zuluf
Objavljeno: Tor Jan 13, 2015 09:57 Naslov sporočila: |
| Realizem ni nekaj, kar bi vsi iskali in to je potrebno spoštovati. Domače okolje se bistveno razlikuje od studijskega in izbira domačih komponent je lahko povsem subjektivna v smislu katera koloracija je komu bolj všeč. Koloriranih komponent je v consumer segmentu malo morje. Pri iskanju takega zvoka potem tudi ni pravih odgovorov. Tako zgodbo večina prodaja. Če ti je všeč, je že dobro, ok, no problem. Malo je samo moteče, da se potem ob poslušanju teh koloriranih sistemov sprožajo debate o hifi reprodukciji in kaj je na splošno bolje in kaj ne, ko pa je glavna poanta uživati v neki določeni koloraciji ki je posamezniku najbolj všeč ali še huje, zasoljeni ceni. Tu potem zadeve zgubijo smisel. |
Objavljeno: Tor Jan 13, 2015 10:03 Naslov sporočila: |
Menim, da stopnjo nevtralnosti monitorja lahko ocenjujemo skozi njegov spekter uporabnosti za različne zvrsti glasbe. Oziroma, v koliko različnih (po glasbi) studijih je uporabljen. To je veliko bolj zanesljiv pokazatelj, kot vse besede kogarkoli.
Kar sem imel prilike govoriti s studijci, ne izpustijo prilike poveličevati 'svoje' zvočnike in kritizirati vse ostale. Ko bodo kolikor toliko enotni, bomo imeli asa tudi za HI-Fi. _________________ Carpe Diem |
Objavljeno: Pet Jan 16, 2015 09:16 Naslov sporočila: |
Zvestoba posnetku je cilj, ki ga je v osnovi zelo lahko doseči - v smislu, da se natanko ve, kaj ti je storiti:
Kupiš monitor zvočnike, ojačevalec, kable in drugo - identično kot v studiju in predvajaš glasbo mixano v istem studiju. Če si še prostor/poslušalnico kopiral, potem mora biti rezultat identičen kot v studiju. Dobiš 100%-no vernost posnetku, tako kot je bilo mišljeno.
Stvar ni poceni, imaš pa zato 100% perfekcijo. Bolje ni mogoče. Če parafraziram reklamo za pralni prašek: kaj je bolj perfektno od perfektnega diamanta?
''go with the pro .. ?'' _________________ Carpe Diem |
Zuluf
Objavljeno: Pet Jan 16, 2015 13:19 Naslov sporočila: |
Ambasador asa za hifi nikoli ne bo (čeprav obstajajo), ker so called hifi tega nikoli ne bo sprejel. Tu gre pretežno za okuse, in to precej pokvarjene, v smislu drago je dobro, statusni simboli, všeč mi je poln bas... V realnosti pa redko kater produkt lahko zvokovno konkurira pro produktu pri isti ceni.
Zamisli si, da bi v studijih delali na sonusih. Vse bi nas ušesa bolela. Če ni visokih iz zvočnikov bi jih pač morali v studiju pojačati in vsi bi imeli probleme. Pa midbas bulo bi blo treba speglat. Zdaj pa povej kje je tu poanta. Diferenciacija produkta za "posebne" idiotske kupce, ki potem to nabavijo in uživajo v estetiki produkta, ampak to z zvokom nima nič. Hifi je pač difernciran, da vsakdo lahko izbere kaj mu je všeč. Pa sej to ni hifi, to je komercialni segment. Igrače. Polni basi, instrumenti s telesom, analitičen zvok in tralala in hopsasa. Treba se je odločit o čem se pogovarjaš, kdo ima dražjega, kdo ima lepšega ali o zvoku.
Pol pa bereš izjave men je bil bolj všeč Dynaudio. Ja bulo ima na basu. We know about bass In to je odlika .... Lahko daš še 5 db plusa na basu bo še bolje... Pol pa v sobo pripelješ to zadevo pa doni. Ja jebi ga ni to enostavno postavljat, pokliči strokovnjaka. Ne more to vsak sam.... Soba je kriva. Kable probaj, za jurja se bo dal zrihtat.
Nazadnje urejal/a Zuluf Pet Jan 16, 2015 15:16; skupaj popravljeno 2 krat |
Zuluf
Objavljeno: Pet Jan 16, 2015 15:14 Naslov sporočila: |
Po moje je vprašanje pro ali komerciala? Kje je tukaj diamant se pa ve. In to ni piramida. Se pa precej hitro pride do diamanta  |
Objavljeno: Pet Jan 16, 2015 15:26 Naslov sporočila: |
Vpliv Lune v Strelcu
Kako vpliva na nase razpolozenje
V naso okolico se vraca vsesplosni optimizem, smisel za humor in navdusenje. Odlicnega razpolozenja smo in pripravljeni na nova dejanja. Polni smo elana in sijajnih idej, ki pa se vcasih izkazejo za vse prej kot prakticne in izvedljive. Zalozeni smo s taksno mero samozavesti, optimizma in poguma, da smo pripravljeni na razlicna tveganja in dejanja, ki zahtevajo od nas prav to. To je zelo ugoden dan za prosnje in zahteve. Vseeno, ali je to visja placa, vloga za kredit ali denarna pomoc... v Luni v Strelcu bo nasa prosnja skoraj zagotovo uslisana.
Predajte se optimizmu
To je dan, ko se z veseljem in navdusenjem podajamo v nove avanture ali se odpravimo na potovanje. Luna v znamenju Strelca nas spodbuja k doseganju osebne neodvisnosti in nam daje dober obcutek za nastope v javnosti, govore in sirjenje svojih idej. Vsepovsod je veliko hrupa in smeha, ponekod pa glasno, a ponavadi neskodljivo besedno dvobojevanje. Vsi smo polni pozitivne energije in se predajamo idealiziranju. Neobremenjeno stopamo v vsak odnos in z lahkoto vzpostavljamo nove stike, ki pa so ponavadi le bezna znanstva. Za zacetek resnega odnosa smo premalo dosledni in objektivni, prav tako kot tudi nas partner.
Brzdajte ostre besede
Vcasih pa nasa odprtost nima meja, zato se v Luni v Strelcu prehitro zgodi, da nam z jezika pobegne kaksna neumnost ali nesramnost. Nestrpni smo in resnicno uzivamo v zbadanju drugih. Se posebej pa radi pretiravamo in povelicujemo vse stvari, dogodke in nacrte, ki jih - polni zanosa - delimo z vsakim, ki nas je pripravljen poslusati. _________________ The only way to do great work is to love what you do |
Telefon: 051383384 |
Zuluf
Objavljeno: Pet Jan 16, 2015 19:04 Naslov sporočila: |
| ambasador je napisal/a: | Zvestoba posnetku je cilj, ki ga je v osnovi zelo lahko doseči - v smislu, da se natanko ve, kaj ti je storiti:
''go with the pro .. ?'' |
Zadeve niso čisto take.
V studijih se zavedajo pomena akustike in imajo izmerjeno linearnost odziva sobe (z zvočniki seveda) in to pri snemanju upoštevajo tako, da dodajo ali odvzamejo jakost zvoka pri posameznih frekvencah. Tudi zato se uporabljajo mešalne mize.
Studiji imajo linearnost nekje do +/- 10 db, boljši so proti +/- 5 db, pa še tam so omejeni z majhnostjo sob, tako da pod kakih 45 - 50 Hz posnamejo bolj na pamet (upoštevaje meritve in izkušnje seveda).
V popolnoma enaki sobi in z enako opremo, boš slišal enako kot v studiju, ne pa enako kot je posneto. _________________ LP |
NLP
Objavljeno: Pet Jan 16, 2015 20:39 Naslov sporočila: |
... uhhh ko bi se vsaj v večini studijev zavedali pomen akustike...
Ponavadi imajo cel kup opreme vredne več 10.000€, akustika pa penice ipd. ki pa vemo da niso efektivne pri nižjih frekvečnih regijah.
Zgodba "zavedanja" je malenkost na višjem nivoju kot pri avdiofilih (da odvzamemo avdiofile ki imajo omejitve zaradi partnerke in družine ter nimajo namenskega prostora za poslušanje).
Ko bi vedeli v kakšnih vseh raznoraznih neurejenih prostorih nastajajo resni projekti...
P.S.: če je soba majhna in se pod določeno mejo ne razvijejo modalne frekvence, še ne pomeni da ne morejo dovolj natančno slišat "teh" še nižjih frekvenc! - seveda pod predpostavko da je bas traping solidno narejen. _________________ Nenad P. |
Objavljeno: Sob Jan 17, 2015 00:56 Naslov sporočila: |
| NLP je napisal/a: | ... uhhh ko bi se vsaj v večini studijev zavedali pomen akustike...
P.S.: če je soba majhna in se pod določeno mejo ne razvijejo modalne frekvence, še ne pomeni da ne morejo dovolj natančno slišat "teh" še nižjih frekvenc! - seveda pod predpostavko da je bas traping solidno narejen. |
V prvem delu se tudi jaz pridružujem mnenju, v studiu penice, kupuje pa najdražji Neumann mikrofon pa mu pol "ne igra"...
V drugem delu "res" , "zavedanje" po akustiki malenkost višja kot pri audiofilih, samo je pa kar nekaj "navad in železnih srajc" pri izbiri opreme, kablov, postavitve, povezave brez vedenja, samo tako "ker tako vsi delajo in imajo", ne da bi vedeli zakaj , pol mu pa rukneš nekaj svojega gor pa pa , igra za nekaj stopnic boljše  _________________ ~ ** ~ |
