Slišnih razlik med dobrimi ojačevalci ni
Pojdi na stran 1, 2, 3, 4, 5, 6, 7, 8  Naslednja
PrispevekObjavljeno: Pon Nov 05, 2012 10:55    Naslov sporočila: Slišnih razlik med dobrimi ojačevalci ni Odgovori s citatom
Zadeva ni zrastla na mojem zeljniku, nanjo me je opozoril prijatelj, priznan audio editor.
Sprva sem mislil, da se zafrkava. Ampak zadeva ima svojo zgodovino.
http://www.stereophile.com/content/carver-challenge
Drug prijatelj je napisal: "If only measurements were adequate to the task." If so, there wouldn't be audiophiles. Mainly because most of them (only a few) can't understand a measurement. It is totally possible to make a poweramp sound as you want, only with measurements. But, of course, you have to have the knowledge for that. ...Remember "The Audio Critic" or "Stereophile" Golden Ears challenge ? "We wanted Bob to fail. We wanted to hear a difference. Among other things, it would have reassured us that our ears really are among the best in the business, despite "70dB nulls."
There were times when we were sure that we had heard such a difference. But, I repeat, each time we'd put the other amplifier in, listen to the same musical passage again, and hear exactly the same thing. According to the rules of the game, Bob had won."
mitko
Prispevkov: 344
PrispevekObjavljeno: Pon Nov 05, 2012 11:42    Naslov sporočila: Odgovori s citatom
A temu bi se potem reklo generičen ojačevalec Very Happy Prosto po farmaciji Laughing Zanimivo, večina ljudi je mnenja, da se vsega ne da izmeriti. Očitno dovolj za ušesa...
p.s.: mestn, naslov si zgrešil: tudi med slabimi jih nebi bilo Smile
PrispevekObjavljeno: Pon Nov 05, 2012 12:40    Naslov sporočila: Odgovori s citatom
mitko je napisal/a:
Večina audiofilov, audio urednikov in predvsem snovalcev komponent in kablov z desetletji prakse meni, da se vsega ne da izmeriti. Wink
In da med dobrimi ojačevalci že dolgo ni velikih razlik. Razlike so torej pri drugih komponentah, ne pri dobrih ojačevalcih.
nomad
Prispevkov: 911
PrispevekObjavljeno: Pon Nov 05, 2012 13:47    Naslov sporočila: Odgovori s citatom
mestn pu je napisal/a:
Kako pa proizvajalci zagotovijo, da ima komponenta neko nemerljivo lastnost ?
Zaplešejo voodoo ples ali zmolijo kakšno ?
V bistvo gre za teološko stališče, saj je potrebna intervenca boga, da v določeno stvar vstavi nam neko popolnoma neznano in nemerljivo lastnost.
Bolj točno, gre za animizem, kjer se nek subjektivni vtis pripisuje stvari.
Animizem je naprimer skrit v trditvi, da je nek sistem muzikaličen.
ANIMIZEM JE ZNAČILNOST MIŠLJENJA V ZGODNJEM OTROŠTVU, KO OTROK ZNAČILNOSTI ŽIVEGA PRIPISUJE NEŽIVIM STVAREM IN PREDMETOM.
Odrasli sicer ne morejo biti več otroci, lahko pa so otročji. In to dejansko je otročji pristop do audia.
Izmeriti se ne da subjektivnosti, kot je recimo sreča, žalost, čudenje itd in v tem primeru subjektivnih vtisov ob poslušanju.
Zunanji svet pa je merljiv, ker je za nas razumljiv edino skozi meritve.
In v proizvodnji audio komponent je vse izmerjeno in normirano, v proizvodnji se ne da uporabljati nemerljivih količin ali lastnosti.
Z meritvami proizvajalci zagotavljajo, da bodo vsi primerki nekega modela zveneli enako.
V resnici gre za aroganco audiofilov, ki nočejo priznati, da povezave med merljivimi podatki in slušnimi vtisi ne poznajo. Namesto, da bi se skušali izobraziti, raje proglasijo meritve za nepomembne in sebe oziroma lastna ušesa za edine arbitre.
Slušne razlike pa namesto z objektivnimi, vsem razumljivimi podatki, opisujejo z divjimi metaforami, ki jih ostali bolj težko razumemo.
Podobno zavajanje je trditev, da med dobrimi ojačevalci ni razlike. Tisto razliko samo preneseš iz termina ojačevalec v termin dobro in velikih. To je isto kot bi rekel, da med enakimi ojačevalci ni razlik. A bi si upal opustiti izraz dobri in velikih in reči samo: med ojačevalci že dolgo ni razlik ?
Nazadnje urejal/a nomad Pon Nov 05, 2012 15:05; skupaj popravljeno 1 krat
Prispevkov: 946
PrispevekObjavljeno: Pon Nov 05, 2012 15:02    Naslov sporočila: Odgovori s citatom
mitko je napisal/a:
So, in to enormne. V načinu, barvi, reliefu kako ojačevalec podaja glasbo.
AB klasa (običajno z veliko povratno vezavo) enostavno ne zmore reproducirati informacij dobrega 300b, ker jih enostavno neg. feedback "odreže" iz spektra. Vse ležijo v polju "šuma".
A klasa resimo reproducira na drugačen način kot AB.Popolnoma drugačen zvok. Mosfet recimo drugače kot običajen tranzistor...
Lampe so zopet svoja zgodba.
Kaj pa se da meriti?
Že prvi in najbolj bazičen podatek THD je čista brca v meglo. Proizvajalci ga navajajo in merijo na "suho" , pod 0,07 že leta ni noben problem. Ko pa priklopiš gor breme(zvočnik), ki povratno vpliva nazaj, pa na prste ene roke lahko prešteješ ojačevalce, ko bi imeli nižjega od 2%.
PrispevekObjavljeno: Pon Nov 05, 2012 15:13    Naslov sporočila: Odgovori s citatom
Bob Carver ni tam kr en "audiofil". "Zakrivil" je kar nekaj danes pogostih topologij ojačevalcev.
Bob je dokazal svoje(link) in v 27 letih od tedaj se človeška ušesa niso spremenila.
Ernie Fisher je v svoji uredniški karieri preposlušal toliko top ojačevalcev kot jih mi vsi skupaj še videli nismo.
Trditev je tudi mene presenetila in jo razumem kot možgansko telovadbo, kot tako jo je zastavil-Carver.
In do danes še nikomur ni uspelo, da bi jo izpodbil.
Še eno mnenje..
Listening is the final judgement of quality. Blind listening tests serve the purpose of taking out external stimuli and evaluate the sound of a system. And measurements are useful to assess the physical reasons a system sounds that way...and to design better ones.
So, to prove the sound quality beyond reasonable doubts, blind tests must be used.
While designing a product you should make measurements to be certain everything is correctly working, without big artifacts, then blind-listen (with the help of trusted golden ears) 2-3 different variants of the product and finally enjoy the selected beast for some months in normal use conditions, in various audio systems and rooms...
PrispevekObjavljeno: Pon Nov 05, 2012 15:35    Naslov sporočila: Odgovori s citatom
Nekaj podobnega kot Bob je pred leti izjavil Tudjman:
"Nema kod nas šovinizma - svi smo mi Hrvati!" Laughing
PrispevekObjavljeno: Pon Nov 05, 2012 16:00    Naslov sporočila: Odgovori s citatom
pasuljaris je napisal/a:
Samo, da Tudjman tega ni dokazal z blind testi, Bob pa je.. Laughing
PrispevekObjavljeno: Pon Nov 05, 2012 16:06    Naslov sporočila: Odgovori s citatom
To je testiral tako dolgo, da so spregledali tudi tisti, ki so blind. Smile Mislim seveda Franjota.
Antun
Prispevkov: 192
Kraj: Kamnik
PrispevekObjavljeno: Pon Nov 05, 2012 16:25    Naslov sporočila: Slišnih razlik med dobrimi ojačevalci ni Odgovori s citatom
"Slišnih razlik med dobrimi ojačevalci ni"
Mislim, da to izjavo ni smiselno vzeti dobesedno. Najprej je treba definirati kaj je dober ojačevalec, dobre ojačevalce dat na polico. Potem se pa že začne stvar okusa kjer presojajo "ušesa in možgani" ker se pojavljajo stvari (ton, odprtost, resolucija, nenapornost itd.), ki jih ni možno meriti in zapisati v tehnično specifikacijo.
Audiatur et altera pars!
PrispevekObjavljeno: Pon Nov 05, 2012 17:44    Naslov sporočila: Odgovori s citatom
Bob Carver je bil že od nekdaj brihtna “buča”, zato je dandanašnji popolnoma “golobučen”. Najbrž poznate tisto zgodbo: “ Neumnim je potrebno lase puliti, pametnim pa kar sami izpadajo”. Wink
Šalo na stran. Štorija o Carverju je postala v avdiofilskih krogih že legendarna in ima po vseh teh letih še precej oboževalcev.
Uredniki dveh revij so Boba sprovocirali, da dokaže svojo teoretično trditev, da na svojem cenenem ojačevalniku simulira zvok dveh tedaj prestižnih in enormno dragih konkurentov. Če me spomin ne vara, je bil eden od njih lampaš Conrad Johnson, drugi pa Mark Levinson ML2.
Osnovni trik carverjeve zamisli je bilo simuliranje prenosne funkcije sistema ojačevalnika. Povedano enostavno, signal ki ga je priklopil na ojačevalnik je v amplitudnem, faznem in časovnem smislu analiziral od vhoda do izhoda ojačevalnika. To je izvedel za oba omenjena ojačevalnika. Ko je definiral matematični funkciji prenosa signala, se je lotil izdelave oziroma adaptacije svojega. Predvideval je, če se bodo vsi ( ali vsaj večina ) električnih parametrov ujemala, se bo ujemal tudi zvok njegovega ojačevalnika z konkurenčnimi modeli. Na tak način je simuliral delovanje ojačevalnika na elektronke in “solid state” ojačevalnika, ki naj bi imela popolnoma različne karakterje zvoka.
V teoriji električnih signalov velja pravilo, da v primeru seštevanja dveh signalov z identičnimi karakteristikami, oziroma oblikami signalov, ki sta fazno obrnjena za 180 stopinj, dobimo izničenje signala, oziroma je njena amplituda enaka nič. Ko jih je priključil na zvočnike, na njih ni bilo nobenega zvoka, oziroma ni bilo električnega signala. S tem si je osebno dokazal, da se je njegov ojačevalnik skoraj poistovetil s konkurenčnim. ( povedano zelo poenostavljeno in mogoče malce konfuzno)
Na podlagi te predpostavke so izvedli slušni blind test med uredniki revije Stereophile in nekaj zunanjih sodelavcev. Uredništvo revije je moralo priznati, da v večini primerov niso zaznali razlike med dvema prototipoma modificiranih Carverjevih ojačevalnikov ter Conrad Johnson in Mark Levinson enotami.
Carver je “slavil zmago”, na strani urednikov pa je ostal grenak priokus, ker so morali v obeh revijah javno objaviti rezultate testa.
Res je tudi, da je Bob Carver odreagiral zelo korektno in še posebej poudaril, da namen demonstracije ni prepričevanje kateri od ojačevalnikov je boljši ali slabši, ampak, da se da z matematično analizo električnih signalov doseči zavidljivo raven poenotenja zvoka ojačevalnikov, ki imajo na tržišču nekajkratni dolarski cenovni razpon. Kvaliteto ojačevalnika/zvoka ni hotel nikoli komentirati.
In še danes so vsi trije na tržišču, čeprav je Carver menjal svoj “trade mark” zaradi finančnih in investicijskih trikov od Phase Linear-ja preko Carverja do sedanjega Sunfire-ja.
mito11
Prispevkov: 152
Kraj: Postojna
PrispevekObjavljeno: Pon Nov 05, 2012 18:02    Naslov sporočila: Odgovori s citatom
Olala, to pa je že drugačna razlaga, ki vzdrži mojo presojo. Ker gola izjava:"Slišnih razlik med dobrimi ojačevalci ni" drži samo v primeru, če je poslušalec gluh.
twom
Prispevkov: 301
PrispevekObjavljeno: Pon Nov 05, 2012 19:12    Naslov sporočila: Odgovori s citatom
vintagesonic je napisal/a:
Ojačevalec matematično ni čisto nič drugega kot prenosna funkcija. Njegova naloga je vhodni signal prenesti na izhod (z večjo amplitudo).
Težave in razlike nastanejo zaradi zelo spremenljivega bremena (zvočnikov).
Zato razlike med A, AB, D in bipolarci, mosfeti, lampami in seveda različnimi topologijami.
...ki sta fazno obrnjena za 180 stopinj, dobimo izničenje signala...
Valovanje se izniči, napetost se pa sešteje in dobi večja moč (npr.: bridge mode ojačevalcev)(en primer je tudi trifazni tok). V tekstu iz linka je na priključenem zvočniku iskal čim manj signala (v nekem trenutku govorijo o 'neznosnem' hrupu (na -40dB ujemanja) ...
Peter
twom
Prispevkov: 301
PrispevekObjavljeno: Pon Nov 05, 2012 19:24    Naslov sporočila: Odgovori s citatom
Bob Carver na wikipediji.
Izgleda, da je res nekaj na tem (da se da narediti 'generik' ojačevalca).
Enake trditve so bile med vrsticami tudi pri Hypex Ncore NC400, kjer so zatrdili, da lahko naredijo poljubno zveneč zvok...
Prispevkov: 1454
PrispevekObjavljeno: Pon Nov 05, 2012 19:34    Naslov sporočila: Odgovori s citatom
Sam se trudim biti v svojem mišlenju in dojemanju racionalen in verjamem, da mi za okus nekaterih to celo preveč uspeva! Wink
Zato tudi en velik del diskusij okoli high-end komponent sprejemam z veliko rezervo! Poznano je, da z naraščajočo ceno komponent dobivamo vse manjši prirast kakovosti, če sploh! S temi top aparati je približno tako kot s parfemi: zapakirati jih v čim manjšo flaško, jo fensi oblikovati, pritegniti par trendi ljudi da stvar zreklamirajo in (pomembno!) postaviti visoko ceno in že po vsaka ženska, ki se hoče malce postaviti, prisegla, kako da trenutno ni boljšega parfema na tem svetu kot je ravno ta (seveda bo to zame pomenilo obvezen obisk duty freeja ob naslednjem potovanju z avionom in začudenje, kako jim vedno paše tisti, ki je med najdražjimi! Twisted Evil ).
Večina nategovanj okoli zvoka ima bolj malo opraviti s samo glasbo in njenim dojemanjem, veliko bolj pa z željo po razkazovanju stvari in pa seveda z možnostjo o neki stvari brez konca diskutirati in dokazovati svoj (ponavadi subjektivni) prav.
Kdor pa čuti neko neobranljivo naotranjo željo analizirati vsak najmanši odtenek reprodukcije, pa že mora biti najmanj glasbeni producent ali razvijalec elektronike ali zvočnikov, sicer lahko postane nevrotična osebnost, če že to ni! Rolling Eyes
Stran 1 od 8
