CES 2011
Pojdi na stran Prejšnja  1, 2, 3, 4, 5, 6, 7, 8
PrispevekObjavljeno: Sre Feb 16, 2011 22:21    Naslov sporočila: Odgovori s citatom
Temu preprosto ni kaj oporekati:
STRADIVARI AUDIO DESIGNS
New hand built reference and statement power plants using solid chassis made from scratch, individual custom housing made out of a solid block of brass for each dual outlet, your choice of silver or copper premium cryo 20A outlets or mono Schuko outlets, custom 1.75" brass spikes, wired with high purity cryo silver in their exclusive classified designs that provides reference performance in A/C conditioning and EMI/RFI noise removal.
A high-end audio system without a Stradivari power plant simply sounds mechanical, dry, congested from top to bottom but especially in the high frequency from 2000 Hz to above 20 kHz where our ears are most sensitive. Along with the dryness and congestion there is a hash in the high frequency that causes listening fatigue and degrades refinement and fine inner detail.
These power plants drastically improves the listening experience of high-end audio music systems by providing high quality noise free A/C to your high-end components without using transformers and circuit boards which limits current and degrades detail, finesse and overall sound quality.
You will find the music sounding natural, with longer decays, clean sibilance, with accurate pin-point precision in the stage, reveling layering and details in recordings not previously heard with ultra clean and transparent high frequency which is needed to achieve air around the instruments and singers. Contact Larry Diaz at High-End Palace for Stradivari Power Plants.
P.S. Tudi Larry Diaz mora od česa živeti, mar ne? Mr. Green
zvocnik
Prispevkov: 790
Kraj: Piran
PrispevekObjavljeno: Sre Feb 16, 2011 23:18    Naslov sporočila: Odgovori s citatom
[quote="tromba"]http://www.soulsonicspeakers.com/news.html[/quote
Samo izsecek iz predstavitvene strani, ki mi je vsec:
Q: Why are they so big?
A: All loudspeakers of this world are too small, including ours. I mean, we are trying to recreate the sound of live musical instruments and human voices as closely as possible and downsizing of the loudspeakers` dimensions and increasing the membrane excursions is a big step away from the higher fidelity. Musical instruments have huge "effective radiation areas" which barely move, even when played really loud and trying to mimic their sound by means of brutally squeezing the music signal through 1" dome tweeters and 5" woofers using extreme membrane excursions is simply a wrong approach.
in je cist resnica.
Information is not knowledge
Knowledge is not wisdom
Wisdom is not truth
Truth is not beauty
Beauty is not love
Love is not music
Music is the best !
FZ
MAre007
Prispevkov: 605
PrispevekObjavljeno: Sre Feb 16, 2011 23:45    Naslov sporočila: Odgovori s citatom
ProJet je napisal/a:
Ni kaj, če je samo delček tega res, potem gre za čudežno škatlico, ki je več kot vredna svojega denarja. Razz
Stran 8 od 8
