DIY zvocniki - samogradnja - nacrti
glasba
Pridružen/-a: Tor Dec 2009 12:30
Prispevkov: 62
PrispevekObjavljeno: Sre Jan 27, 2010 19:34    Naslov sporočila: DIY zvocniki - samogradnja - nacrti Odgovori s citatom
imate kaksne linke, kje bi bili objavljeni nacrti DIY samogradenj zvocnikov, ali prodajalcev kit kompletov, sest. delov za kretnice itd...
npr, ce govorimo o sirokopasovnih..Fostex, Seas, Monacor...
rad bi si namrec naredil regal zvocnike, potrebujem le podatke/mere in vrednosti za kretnico..
hvala
glasba ( ki jo cutis ze ob petju cirkularke:-)
PrispevekObjavljeno: Sre Jan 27, 2010 19:43    Naslov sporočila: Odgovori s citatom
Posredujem ti odgovor, ki sem ga dobil od Stylos Sys Team:
Če želite izdelati FR zvočnik obstajajo tudi alternetivne enote, ki so zelo dobre, boljše, recimo:
Tangband W4-1320 58EUR (odlična FR enota)
Tangband W4-1337 80EUR (odlična FR enota)
MarkAudio so nove hi-tech enote na trgu........za enkrat je cena zelo ugodna, glede na kvaliteto
MarkAudio Alpair 5 116EUR/par
The Alpair 5 is a special driver. It's a single suspension driver with no spider. The design optimizes low range performance. Compared to typical tweeters, the large cone area delivers more detail in the middle and high range. The Alpair 5 is easy to partner with sub woofers and larger drivers. It's also useful unit on its own for mini audio and desktop applications. The copper-gold cone and cap finish uses our "soft" surface treatment. The process delivers a higher density coating that increases the mass of the cone and produces a pre-determined pattern of control on rigidity. The result is a driver with a very sweet character in the middle and high range that retains musical detail.
Features
Much effort has placed in shaping the cone to deliver a flatter response up to 10kHz while retaining its characteristic +9dB gain above 10kHz. The total Q has also been raised to deliver a sharper LF fall-off for easier integration for those builders using sub-woofers. Crossover designs also benefit, as the usable frequency range remains wide and better defined.
MarkAudio Alpair7 150EUR/par
The Alpair 7 is a rare (possibly unique) driver in this size and class. Its primary feature is its extended high range, operating to 30-kHz the Alpair 7 eliminates the need for a tweeter. The driver achieves this performance without using a whizzer or co-axial centre tweeter. The Alpair 7 is a purist single cone/cap design.
This driver incorporates a new cone multi-forming technology originally developed in Japan. The cones are made using 7 separate forming and trimming processes, all controlled via CNC operation. The accuracy of this technology is superior to conventional spun and press methods.
Tadashi Matsubara San, a most experienced senior driver designer from Japan has produced the rear suspension. It is unique and exclusively made for the Alpair 7. Lui Yi Ping from Taiwan is a specialist in front suspension design. He has produced the 7ʼs suspension as the most advanced of its type so far. It is ultra-thin and the production process for this component is all new. The same exclusivity is also applied to the frame, coil, connectors, every part for this driver is unique custom designed.
The acoustic result is remarkable for a driver of this size, delivering outstanding clarity, detail and musical realism.
glasba
Prispevkov: 62
PrispevekObjavljeno: Sre Jan 27, 2010 19:56    Naslov sporočila: Odgovori s citatom
hvala, nekaj vec ze vem.
linki z nacrti, linki...
orc.perc
Prispevkov: 527
Kraj: Posr.Park
PrispevekObjavljeno: Sre Jan 27, 2010 20:15    Naslov sporočila: Odgovori s citatom
http://www.diyaudio.com/forums/loudspeakers/
Izbiraš med meniji:
-mešano na žaru
-pečenka
-jetrca..
Pa dober tek!
p.s.register!
-1/3oct.REar
PrispevekObjavljeno: Sre Jan 27, 2010 20:41    Naslov sporočila: Odgovori s citatom
http://www.visaton.com/en/bauvorschlaege/index.html
glasba
Prispevkov: 62
PrispevekObjavljeno: Sre Jan 27, 2010 20:46    Naslov sporočila: Odgovori s citatom
visaton link je zelooo ok...vse na enem mestu. Very Happy
ponekod opazam, da so naprimer visokotonci z nizkotonci vezani v protifazi? kaj potem + in - obrne sama kretnica? Shocked
PrispevekObjavljeno: Sre Jan 27, 2010 20:54    Naslov sporočila: Odgovori s citatom
glasba je napisal/a:
Daleč od tega da bi bilo vse na enem mestu, je pa vredu za začetek.
PrispevekObjavljeno: Sre Jan 27, 2010 23:16    Naslov sporočila: Odgovori s citatom
http://www.audiopuls.hr/diy/chameleon.html
orc.perc
Prispevkov: 527
Kraj: Posr.Park
PrispevekObjavljeno: Čet Jan 28, 2010 04:17    Naslov sporočila: Odgovori s citatom
impedanca,
vztrajaj, išči,
the truth is out there...
-1/3oct.REar
AUDIOEXPERT
Prispevkov: 407
Kraj: CELJE
PrispevekObjavljeno: Čet Jan 28, 2010 13:46    Naslov sporočila: Odgovori s citatom
www.audiodiy.org
www.audioexpert.si
miran
Pridružen/-a: Pet Maj 2008 14:57
Prispevkov: 31
PrispevekObjavljeno: Čet Jan 28, 2010 14:00    Naslov sporočila: Re: DIY zvocniki - samogradnja - nacrti Odgovori s citatom
imate kaksne linke, kje bi bili objavljeni nacrti DIY samogradenj zvocnikov,...
Ene par uporabnih za začetek:
http://www.ciare.com/consumer_en/guide_progetti_home.htm
http://www.ciare.com/consumer_en/guide_progetti_cinema.htm
LP, Miran
AUDIOEXPERT
Prispevkov: 407
Kraj: CELJE
PrispevekObjavljeno: Čet Jan 28, 2010 14:49    Naslov sporočila: Odgovori s citatom
http://www.intertechnik.de/Lautsprecher-Shop/Bauvorschl%C3%A4ge/1768,de,7.html?PHPSESSID=3e7a5da5bd58ffda5322e7f3d0bcbaa1
Tukaj imaš veliko načrtov za SEAS in ostale enote !
www.audioexpert.si
PrispevekObjavljeno: Čet Jan 28, 2010 15:32    Naslov sporočila: Odgovori s citatom
Nobenih načrtov ne poptrebuješ ... ... samo priklopiš kvalitetne kable in postaviš v regal in dobiš drag,vrhunski open baffle ...
Feastrex
glasba
Prispevkov: 62
PrispevekObjavljeno: Čet Jan 28, 2010 17:18    Naslov sporočila: Odgovori s citatom
ooo, nekaj dela se bo nabralo.
100% sem, da se lahko taksni optimirani boxi kosajo z x krat -drazjimi serijskimi (cas, trud, material pozabimo)
PrispevekObjavljeno: Sob Jan 30, 2010 11:36    Naslov sporočila: Odgovori s citatom
kaj pa kakšni Mangerji? Rabiš samo aktivni sub(režeš ga ca 100hz) in je to to, dela super , odzivni čas 13ms.Škatla nezahtevna rabi zaprtih 8l.
Imam doma en par +center za 5.1 , sub je še začasen a pride Perless xxxl12 z pasivno membrano downfire.
http://www.manger-msw.com/index.php?scope=portal&id=&pid=w2m8lr7RP02hoHSSIpGwtqwK6RH1W5ps&language=en
