nomad
Objavljeno: Sob Dec 18, 2010 13:18 Naslov sporočila: |
Eden izmed popularnih mitov je, da slišimo različno in imamo zato različne prioritete. To pa naj bi bil tudi razlog, da na trgu obstajajo tako različne komponente, pristopi in s tem tudi različen zvok različnih sitemov.
Kevin Voeck, glavni konstruktor pri Revelu se s tem ne strinja:
... we know that everyone with reasonably “normal” physical hearing ability prefer the same speakers. It’s not about “personal preference” after all. In addition, we know that everyone likes the same speakers for a variety of kinds of music. There is no need for “rock” or “classical” speakers.
Zanimivo je tudi njegovo stališče kaj je pomembno pri zvoku. Tu se kar strinjam z njim, timbre je najpomembnejši aspekt reprodukcije – če je tu vse v redu, potem tudi ostali elementi reprodukcije klapajo.
When designing a loudspeaker what are the three most important aspects of a loudspeaker according to you that one must get right?
Kevin: Timbre is the overwhelming aspect. Based on our blind listening tests timbre is the thing that differentiates between good and bad loudspeakers, but also between good and great loudspeakers. So timbre is kind of a broad term. It incorporates balance, frequency balance, or it can be thought of very roughly as frequency response. That’s a little dangerous because, not to infer that one on-axis measurement tells you what the frequency response is in a loudspeaker. It doesn’t. Other areas like off-axis response are very critical and we’ve learned that very far off-axis response like 60-75 degrees is very critical. Almost no one even measures it, let alone designs loudspeakers that are optimized at that sort of angle. But we’ve looked at real world situations and found that the all-important side-wall first reflection is a function of the speaker’s output at that kind of angle in the vast majority of listening rooms. So it means that you’re going to be hearing that kind of sound. You will hear it with a slight delay, and in many rooms without very much attenuation. So optimizing the response at that kind of extreme angle is very, very important. And then the power response, the reverberant field that we hear a little later in time is also important. So we literally design for all of those areas: the direct sound, the first reflection sound, and the reverberant field, because we know that all those three things are huge contributors to the timbre, to our perception of the speaker’s timbre.
Celoten intervju je na:
http://www.hometheaterhifi.com/volume_11_2/feature-interview-kevin-voecks-4-2004.html |
Objavljeno: Sob Dec 18, 2010 14:52 Naslov sporočila: |
Nekaj podobnega je pred časom objavila tudi nemška revija Stereoplay.Poanta je, da so mnogotera nategovanja o dobrem in slabšem zvoku v bistvu brez podlage, ker ljudje pač zvok sprejemamo individualno in je tako tudi všečnost zelo relativen pojem.
Absolutno to velja v primerjavah komponent podobnih kakovostnih kategorij, posebej morda ravno v high-endu.Se ne govori v tri dni o "ameriškem", "ngleškem", "japonskem" ali "nemškem" zvoku!Po nekaterih izvajanjih bi lahko bilo govora tudi o "slovenskem" zvoku.
Gre pa to tako daleč, da je nekomu povsem vseeno, ali posluša nek hreščeč zvok z avtoradia, ob katerem že jaz izgubljam živce, na drugi strani pa imamo ljudi, ki verjamejo, da slišijo tisto, česar bi že po nekih fizikalno-akustičnih zakonitostih ne mogli. |
orc.perc
Objavljeno: Sob Dec 18, 2010 15:26 Naslov sporočila: |
...in uživajo v nosljajočih slovenskih estradnicah in
koncertih razglašenih vaških plehmuzik.... _________________ -1/3oct.REar |
nomad
Objavljeno: Sob Dec 18, 2010 15:38 Naslov sporočila: |
Zvok sistema ali pa ameriški, angleški itd zvok je skupek značilnih popačenj ki tvori razliko med vhodnim in izhodnim signalom. Tu ni nič subjektivnega, temveč trdno objektivno dejstvo. Če med vhodnim in izhodnim signalom ni nobene druge razlike kot samo gain, potem je sistem nevtralen in nima lastnega zvoka. High fidelity je visoka zvestost izvornemu zvoku, torej je hi fi ali high end sistem tisti, ki čim manj spreminja izvorni zvok, dodaja čim manj svojega zvoka. Zato tu ni prostora za kakšno debatiranje o okusih in subjektivnosti dobrega zvoka. To je napačen pristop, ki z Hi Fijem nima nič, to je potem pleasure fi, to pa nima nič s poslušanjem glasbe, temveč s psihološkimi učinki posameznih popačenj. V praksi popolnoma nevtralnega sistem res ne moremo doseči a to še ne pomeni da nam ta ne more biti izhodišče. Ta razlika ki loči izhodni zvok od vhodnega pa je tisto kar moramo minimalizirati, ne pa iz tega narediti cilj, smisel in fetiš audiofilstva. Namen audio opreme je poslušanje glasbe in ne poslušanje zvoka.
Kar je hotel povedati Kevin Voecks je, da ne obstajajo različni okusi in da različni poslušalci v dobro kontroliranih razmerah vedno preferirajo iste zvočnike, ne glede na zvrst glasbe in lastno kulturno ozadje. Skratka, da je kvaliteta zvoka v audiu nekaj objektivnega in ne stvar okusa ali subjektivnih preferenc. Subjektivnost in okus se prikradeta naknadno, iz kulturnega konteksta. |
zvocnik
Objavljeno: Sob Dec 18, 2010 16:54 Naslov sporočila: |
| nomad je napisal/a: | Eden izmed popularnih mitov je, da slišimo različno in imamo zato različne prioritete. To pa naj bi bil tudi razlog, da na trgu obstajajo tako različne komponente, pristopi in s tem tudi različen zvok različnih sitemov.
Koncno nekaj pametnega.
In ko se ze pise o raznih tipih zvokov, kaj se pa rece takrat, ko 'ameriski zvok' igra v evropski hisi?
Edino kar drzi je to, da bolj, ko 'razumemo' (ne v smislu tehnicne analize ampak v sebi) zvokove bolj 'naravna' bo tudi reprodukcija doma. Vcasih si je pac potrebno kaj tudi priznati.
Knowledge is not wisdom
Wisdom is not truth
Truth is not beauty
Beauty is not love
Love is not music
Music is the best !
FZ |
Telefon: 041 737 410 |
Objavljeno: Sob Dec 18, 2010 22:37 Naslov sporočila: |
"Nevtralna komponenta" in konsenz o njenem obstoju je le še eden izmed množice mitov, ki ga večinoma "prodaja" pro-audio srenja.
Take komponente ni in nikoli ne bo obstajala, podobno kot bi nekdo trdil, da je fraktal (v našem primeru razdrobljenost teoretičnih kriterijev) končen.
nomad
Objavljeno: Ned Dec 19, 2010 15:37 Naslov sporočila: |
| ProJet je napisal/a: | "Nevtralna komponenta" in konsenz o njenem obstoju je le še eden izmed množice mitov, ki ga večinoma "prodaja" pro-audio srenja.
Take komponente ni in nikoli ne bo obstajala, podobno kot bi nekdo trdil, da je fraktal (v našem primeru razdrobljenost teoretičnih kriterijev) končen.  |
Izgleda da imamo malce konceptualne zmede. Torej trdiš, da je fraktal neskončen – kako pa boš potem razložil to da sem uspel v pol ure skidati parking.
In kako boš potem razložil naš obstoj, saj če obstaja samo en neskončen fraktal, potem ni prostora za nič drugega, tudi za nas ne. In kako ti je uspelo prilimat sliko nečesa kar je neskončno ?
Trditve je pač treba postaviti v pravi kontekst. In ravno zato da se izognem pametnjačenju sem zgoraj podal v bistvu tradicionalni pogled na nevtralnost.
Zato ga je treba razumeti v kontekstu zgodovine audia. In v to usmeriti tudi kritiko, če komu ta koncept ne diši, saj jaz nisem pravi naslovnik. Če pa tega koncepta nekdo ne razume, še ne pomeni da ne obstaja.
Moj lastni pogled na audio nevtralnost je sicer malce širši (čeprav zajema tudi tradicionalni pogled), vendar tu o njem ne bi debatiral. Če koga zanima, nekaj dobrih nastavkov je podal Tommy The Cat tule: http://www.goodsoundclub.com/Forums/ShowPost.aspx?postID=4116#4116.
Če se spet vrnem nazaj, sem eksplicitno napisal, da popolnoma nevtralnega sistema ni, saj je nevtralnost koncept. Nevtralnost ni pozitvna lastnost, ampak pomeni manjko nečesa. Nevtralnosti ne moreš preprosto dodati, ker sama na sebi ne obstaja. Je vedno produkt medsebojnega razmerja več elementov. Zato je vedno v relaciji do nečesa (recimo tonska nevtralnost ...), ni nikoli absolutna. Zato nevtralnosti kot take ne moreš slišati, slišiš pa njene učinke.
Da ne bi preveč teoretizirali, problematiko se da osvetliti tudi bolj preprosto:
| Citiram: | Your system is becoming more neutral whenever you change a system element (component, cable, room treatment, etc.) and you get the following results:
(1) Individual pieces of music sound more unique.
(2) Your music collection sounds more diverse.
This theory occurred to me one day when I changed amps and noticed that the timbres of instruments were suddenly more distinct from one another. With the old amp, all instruments seemed to have a common harmonic element (the signature of the amp?!). With the new amp, individual instrument timbres sounded more unique and the range of instrument timbres sounded more diverse. I went on to notice that whole songs (and even whole albums) sounded more unique, and that my music collection, taken as a whole, sounded more diverse.
That led me to the following idea: If, after changing a system element, (1) individual pieces of music sound more unique, and (2) your music collection sounds more diverse, then your system is contributing less of its own signature to the music. And less signature means more neutral.
http://forum.audiogon.com/cgi-bin/fr.pl?ymisc&1257469878&read&keyw&zzchase
Trdim, da je tradicionalni pristop k audiu takšen da mora sistem čim manj odvzeti ali dodati vhodnemu signalu, da mora biti čimbolj nevtralen. Kakšen pa je potem alternativni koncept če ta ne drži ? Ali je naloga sistema da kaj dodaja ali odvzame in kaj naj bi to bilo ?
Edina alternativa konceptu nevtralnosti, ki jo poznam je audio realtivizem, kot je novodobni pristop k audiu poimenoval Artur Salvatore:
| Citiram: | What is Audio Relativism?
It is the belief system that virtually every component has strong merit and can produce "great sound", for someone's "tastes", if it is matched correctly with other components.
What are (some of) the ultimate implications of this theory?
1. Every component has some validity in the audio marketplace.
2. No component is inherently superior to another.
3. All sound reproduction differences are just a simple matter of taste.
4. There is no objective standard to aim for.
5. (High) Fidelity to the source, or in general, is irrelevant.
6. Audio is an "Art Form", like poetry and sculpting, rather than a science.
This "belief system" is very convenient for its creators; the audio magazines and their 'reviewers'. It provides them with the ability (and the excuse) to find some "good", or some "justification" to purchase, within every single component that is reviewed by them. How?
Because, if their belief is true, each and every component, under the right conditions, can equally satisfy listeners as much as any other component, for either the money or in the absolute sense. It's just a matter of time, or luck, before you find the right "match".
In effect: this theory means that all component performance is "relative" and with no "absolutes"; only "possibilities" exist. |
http://www.high-endaudio.com/philos.html
Glede na pisanje v tem forumu postaja prav slednje prevladujoč pogled na audio. |
nomad
Objavljeno: Ned Dec 19, 2010 15:46 Naslov sporočila: |
Vojko, s tvojimi posti imam večji problem. Predvsem s tvojim domišljavim tonom. Kar naprej bi nekaj šolal, potem pa v bistvu nič ne poveš in samo pripopaš kaj kar je napisala ali rekla kakšna avtoriteta, pa pravzaprav nima nič opraviti z določeno temo.
Biti pameten tako da se skriva za tujimi teksti zna vsak.
Vsebinsko pa s tabo ne morem debatirati, saj v nisi nič povedal.
Kar pa se tiče Johna Curla, v testih njegovih komponent se beseda nevtralnost pojavlja tako pogosto, da kakšna nadaljna razlaga ni potrebna. Samo par odlomkov:
| Citiram: | If you think of a sound system as a window into your recordings, the 2100/2125 combo is like Windex. It's clean, neutral presentation does wonders with excellent recordings...
The Parasound "sound" is uncompromisingly neutral, so combining it with speakers that are similarly revealing could result in a system that is more a tool than a toy. Some audiophiles will shudder at the mere suggestion that there could be anything "wrong" with that, as the goal for many is to recreate as accurately as possible exactly what the sound engineer intended in their recordings.
http://www.enjoythemusic.com/magazine/equipment/1107/parasound_2100_2125.htm
| Citiram: | JC2 Preamp, $4000, PRODUCT of the YEAR 09, ABSOLUTE SOUND GOLDEN EAR AWARD; EDITOR'S CHOICE 3/10
"Neutral & natural, transparent, quick & delicately detailed; a masterwork." BUYER'S GUIDE, ABSOLUTE SOUND Spring 2010
"The BEST BARGAIN in a HIGH END PREAMP. This is the closest I've heard solid state come to a fundamentally neutral sound. It preserves fine harmonic & dynamic detail, air & bloom in the midband; [plus] the frequency extremes, which is unique in a solid state preamp. EXTREME RARITY - A REFERENCE QUALITY PRODUCT THAT MANY of us can ACTUALLY AFFORD." GOLDEN EAR AWARD, ABSOLUTE SOUND 7/08 |
http://www.parasound.com/halo/reviews.php
Ko se boš drugič spet skrival za kakšno avtoriteto pa le poskrbi, da bo zares mislila to kar ti misliš da misli. |
Objavljeno: Ned Dec 19, 2010 16:06 Naslov sporočila: |
Nomad kje si bil pri matematiki, sedel na ušesih?
Fraktal (preberi si matematično definicijo fraktala preden pametnjačiš) je najustreznejša prispodoba utopične misli, da v univerzumu obstaja nevtralnost glede na katerikoli pojav. Česa takega ni, ne more in nikoli ne bo obstajalo, ker živimo v nenehno spreminjajočem se svetu tudi na subatomsko-energetski ravni tako, da je tvoje filozofiranje glede nevtralnosti enako "piš me v uh" teoriji.
Ne glede na kakršnekoli rezultate fizikalnih (kako prozaično) meritev, bo o kvaliteti in "nevtralnosti" katerekoli komponente odločal edinole konsenz določene skupine kompetentnih posameznikov in nič drugega.
"Tradicionalni koncept nevtralnosti", hmm lepo si to spesnil, vem še za najmanj tisoč podobnih konceptov, ki jih očitno še nisi osvojil ali pa ti enostavno ne "potegne". Hja filozofski pristop ala Nomad ima pa res iztočnico za neskončno kramljanje o neki kvazi nevtralnosti, z metodo, Pazi!, poslušanja na kontrast. Ha ha ha, a si mogoče pesnik v prostem času? Če slučajno nisi pesnik, si pa pravi generator mitov, takorekoč mitološko bitje, da se striktno omejimo na vsebino teme.  |
Objavljeno: Ned Dec 19, 2010 23:55 Naslov sporočila: |
Nomad, ti si ena taka slika.
Simpatična, da ne bo pomote.
Poglej, , audio ni moje področje-samo hobi. Imam svoje uho, in veselje, to je vse. Inženirsko nimam pojma; vem in slišim kaj je dobro, kako se pride do tega pa me jasno fascnira. En tak ki bistveno bolj razume je recimo ProJet. Midva pa recimo ne-kaneda' '.Ko bom v penziji, se bom poglobil, ker me stvar res veseli. Je pa za nek rezultat treba ogromno časa-pred njim pa še cel kup osnov elektrotehnike preštudirat, potem pa pridejo na vrsto stvari o katerih piše Crul. So pa to vglavnem čisto znanstveni teksti, pa vse je bilo že napisano.
Niso pa taka sveta prepoščina, kot si predstavljaš. Tvoja gorečnost okoli "nevtralnosti" in cerebralno forenzičnega dojemanja audia je sicer hvalevredna enciklopedična obsesija-z realnostjo pa nima kaj dosti.
Tekst ti namiguje natančno na to. Piše o distorziji in transparentnosti, kar te obseda, ane? Vsakemu ojačevalcu lahko pripelješ feedback na 40 do 80+ Bb, TDH bo 0.00005%,(kake starejše Yamahe in "japonci" so lep zgled) zvoka in "muzike " pa ne bo. Kaj pa zdaj? To zna naredit vsak v 1 letniku eklktro faksa. Pa je komponenta po tvojem dojemanju absolutno "nevtralna"?' '
Enako se lahko izogneš transformatorjem v končni stopnji, dobiš večji "bandwidth", spet več "transparentnosti", ne pa nujno boljši performance?
Samo kdaj kaj najdem kar je res kvalitetno in vredno branja, in namesto diletantskega pleteničenja po forumu ki ga je itak preveč, če ne kar večina, pa pač to prilepim. To je vse. Jasno pa "prilepljenoi" krepko presega moje znanje, ne pa moje radovednosti.In niti v norosti si ne domišljam da bi se postavljal ob bok ljudem, ki so se celo življenje ukvarjali s tem. O tem nimam pojma. Sploh pa mi ne pade na pamet, da bi o tem debatiral s teboj. Veš, presega najin domet.
Vidim da si stvar predelal, in vestno "pogooglal". Si pač take sorte, da rabiš vedno potrditev svojih cerebralnih fiksacij. Pa je vseeno, važno je, da se širijo obzorja, saj to je namen foruma. Ergo, moj namen je bil dosežen.
Nima pa to, kar piše na tem linku nič veliko s tvojim tipom zvoka, ki ga imaš rad. Verjami mi. In tu je tvoj paradox' '
Se pa strinjam da so ATC eni redkih res "pravih" zvočnikov. Ampak "tamali"...' '
Daj, mal se sprosti stari. |
Objavljeno: Pon Dec 20, 2010 16:44 Naslov sporočila: |
Ko človek malo preleti tule napopane članke, se izlušči, da različni audio snovalci komponent v samih zasnovah ojačevalcev poudarijo ene harmonike bolj kot druge(navedba-preselil je drugi harmonik v tretjega! -pomeni, reprodukciji tretjega se je posvetil bolj, jo poudaril, nekdo drug pa obratno) in če dodamo temu enormen vpliv prostora in medsebojni vpliv vseh komponent, bi na osnovi ugotovitve o različno implementiranih harmonikih lahko rekli, da je high end čista utopija.
Že ko hodimo okoli h komu poslušat nekaj specifičnega, tudi kaj kar ima tehnično-amplitudno znivelirane harmonike, ima zadeva nekaj kar naša domača fršterkerija nima.
Drugače reproducirane harmonike in zavedajmo se.
Če nam paše timbre v določenih harmonikih, nam fršterkerija, ki ga nima spiljenega v točno teh harmonikih, ne bo všeč, za lastnika pa bo popolna.
Šiptarski slaščičarji bruhajo ob tortah. Normalno.
Vrhunski avdiofili pa ne bruhajo, če poslušajo samo vrhunsko fršterkerijo?
Dajte me hecat, potem to kar poslušajo očitno ni tako zelo vrhunsko, po domače-radi imajo svoj sistem in še kak sistem znancev, vse dokler se ga ne naveličajo in o tem katere harmonike igra njihov sistem poudarjeno, ne razmišljajo, ker niti slučajno ne vedo katere, niti jih ne briga, niti tega nočejo vedet, če ne, bi pozorno brali o tem in se zapičili v to, saj gre za primarno-bistveno podmeno zasnove sistema..  |
Objavljeno: Pon Dec 20, 2010 17:11 Naslov sporočila: |
 | Ker sta to dokazala v praksi, sta letos dva Rusa dobila Nobelovo za Grafen.
Po njunem so stranske špičke na rjavem delu znanega v resnici veje, ki imajo poganjke novih vejic-spoznanj. Vse to v okviru trenutno fraktalno že znanega, ki pa nikoli ne bo do konca spoznano, torej bi fraktal po njunem moral biti podoben novoletni jelki..
Sicer pa tale slika Fraktala malce nenavadno spominja na piramidalni graf Vedske matematike, le da gre tam za piramidalno 3D računanje enačb po katerem se lahko baje vsi otroci naučijo računanja srednje zapletenih enačb že do petega leta.
http://nauka.adsoglasi.com/fizikamatematika/vedskamatematika.php |
nomad
Objavljeno: Pon Dec 20, 2010 18:41 Naslov sporočila: |
Česa takega ni, ne more in nikoli ne bo obstajalo, ker živimo v nenehno spreminjajočem se svetu tudi na subatomsko-energetski ravni tako, da je tvoje filozofiranje glede nevtralnosti enako "piš me v uh" teoriji. |
In kakšna je povezava med subatomsko-energetsko ravnijo in audio nevtralnostjo ?
A to potem pomeni da da tudi Švica ne more biti nevtralna ? Ali pa da ne moremo izmeriti navtralnega Ph-ja. Meni se zdi tako absolutiziranje pojma nevtralnosti popolnoma zgrešeno. Pojem nevtralnosti je vedno nanašajoč, to sem napisal tudi zgoraj in zato nevtralnost kot jo opisuješ ti ni neka univerzalna kategorija.
Švica verjetno nima nevtralnega zvoka ali nevtralen Ph ampak je politično nevtralna.
Audio sistem pa verjetno ne more biti politično nevtralen. Skratka med temi pojmi ni neposredne povezave in nevtralnost v politiki je nekaj drugega kot pa v audiu ali pa v fiziki.
Zgoraj sem podal nekaj definicij nevtralnosti v audiu (nobena ni moja, da ne bo pomote – to ni moje filozofiranje o nevtralnosti, temveč navajanje drugih) in s kako subatomsko-energetsko ravnijo nimajo nobene povezave. In tudi ne gre za kakšno veliko teoretiziranje, temveč za dokaj praktično zadevo ki se da v praksi prav dobro slišati (tudi o tem govorijo gornji citati). A mogoče kdo misli da recimo en sistem ne more biti bolj tonsko nevtralen kot drugi zato ker absolutne nevtralnosti ni ?
Zadevo tudi nisem postavil kot neko absolutno resnico, ampak tako da se da o tem tudi debatirati. Ampak na bolj praktičen in vsakdanji način in ne zateženo z nekimi resnicami o svetu na subatomsko-energetski ravni.
O nevtralnosti in kvaliteti katrekoli komponente bom zase odločal kar sam in ne potrebujem konsenza neke določene skupine kompetentnih posameznikov.
Ne vem kateri bi bili še ostali tisoči podobnih konceptov. Po kakšnem lepem kupčku prebranih knjig, dobesedno tisočih izvodih raznoraznih audio revij, vseh živih internetnih strani in več kot tridesetletnem ukvarjanju z audiem nisem naletel na ne vem kakšno množico različnih konceptov nevtralnosti v audiu reprodukciji. “A neutral component or system neither adds nor subtracts from the music it seeks to convey, allowing the signal to flow through unencumbered, faithfully reproducing whatever is in the recording.” – to bi bil koncept nevtralnosti, ki ima skoraj univerzalni konsenz. Zato sem ga poimenoval za tradicionalnega.
Zame je ta definicija premalo in veliko bliže mi je to kar o audio nevtralnosti piše Tommy The Cat. Povedano drugače, o nevtralnosti ne moremo govoriti brez upoštevanja kulturnega konteksta. Kogar to zanima, je v gornjem postu dovolj linkov. In če bo kogar zanimala čisto konktretno praktična plat, lahko kaj povem tudi o tem.
Poslušanje na kontrast in primerjanje s kontrastom pa so zadeve o katerih sem pisal že večkrat. In tudi tega si nisem izmislil jaz, ampak Leonard Norwitz in Peter Qvortrup kar kakih dvajset let nazaj. Tako se pač imenuje ta metoda in ne vem kaj bi tu bilo kaj mističnega ali pesniškega, to je pač ime in ne metafora ali zgodba. IN tudi nič filozofskega ni v tem, to je dokaj praktična metoda in tudi opis je zelo pragmatično praktičen. Ne vem, mogoče tega res na poznaš, ampak med audiofili je to dokaj znana zadeva. Še kratek opis z linki, ki sem si ga izposodil iz 6.moons.
If we propose that the quality of audio devices is described by their ability to differentiate audio signals from recordings, cables, sources etc., then the Luxman L-550A II will sit on the very top of amplifiers up to 20000zl, sharing the peak with the Aaron No.1.a. What does differentiating imply? It means that the more a device magnifies differences, the fewer obstacles remain in its signal path. In other words, it is more transparent and does less damage to the signal. This is one of the best but of course not only methodologies for conducting listening research. A splendid article covering this topic while showing the thinking of the folks of the American Internet magazine EnjoyTheMusic can be found under Are You On The Road To... Audio Hell? by Leonard Norwitz (EnjoyTheMusic) and Peter Qvortrup (Audio Note UK) who propose that this is the only 'scientific' way of comparison. Comparative tests using as reference devices from the same price tier or much costlier equipment are essentially flawed as their reference points are imperfect and this method tells little about the comparison to a live event. That last one is only partially helpful as we must rely on a memory of what we heard which does not correlate to the individual recordings we hear at home. There is much truth in those statements. Data gathered in the process of differentiation evaluations are powerful and easily accessible. In my opinion, this method isn't the whole truth because it tells nothing about many aspects of the sound like tonal balance yet it is a valid part of my own tests.
The four aspects I try to assess are:
• comparison by contrast - a Leonard Norwitz description here
• comparison to a much costlier known reference point,
• comparison to a reference point from the same price tier
• comparison to a live event.
No death threats please for placing the live event at the end of the list. For one, all entries are equal. Two, knowledge of the sound of real instruments is a 'basic' knowledge and part of a normal education process on listening, learning to use the brain and understanding how things should sound. We cannot bring a concert into our homes nor would it be the same acoustics. It becomes a different performance. Remembering a concert experience invokes a time delay that is too large to play anything but a supporting role. Those are of course the basics but it is on those that we need to build detailed research to describe how a device sounds.
http://www.6moons.com/audioreviews/luxman/luxman_2.html |
nomad
Objavljeno: Pon Dec 20, 2010 18:42 Naslov sporočila: |
Vojko, to kar si povedal zgoraj, moram priznati, ne razumem dobro. Jaz sem govoril o ocenjevanju kvalitete zvoka, ti pa si pisal kot da gre za izdelovanje ojačevalcev. O izdelovanju ojačevalcev res ne vem prav veliko in zato ne vem kako narediti nevtralen ojačevalec, mislim pa da znam kar dobro oceniti kvaliteto zvoka in tudi ugotoviti katera komponenta je bolj nevtralna od druge. To da nekdo zna narediti ojačevalec pa tudi še ne pomeni, da ima kaj pojma o audiu.
Okoli nevtralnosti nisem bil nič kaj gorečen, celo napisal sem da imam o tem malce drugačno mnenje od teh, ki sem jih posredoval. To je pač nekaj kar si nisem izmislil jaz, o tem audiofili debatirajo odkar pomnim in je eden najpogostejših in tudi najbolj uveljavljenih izrazov. Z zelo širokim konsenzom audiofilov o tem kaj naj bi pomenil. Uporabljajo ga vsi, kaka dva tedna nazaj je bilo recimo omenjeno, da so grafitni podstavki bolj nevtralni ... In težko boš našel kakršnokoli audio revijo v kateri se ta izraz ne bo pojavil niti enkrat. Ne vem zakaj zdaj taka “gonja” proti nevtralnosti.
In kaj naj bi bilo to cerebralno forenzično dojemanje audia mi tudi ni jasno. Zase smatram da sem klasični audiofil z dokaj tradicionalnim pogledom na audio in mislim, da moje ideje niso nič kaj ekscesne. In tudi kakšnih fiksacij glede tega nimam. Mogoče zavaja moj način pisanja in malce filozofski pristop, ampak med mojimi posti so tudi čisto konkretne in praktične observacije. Pač nimam nobenih zadržkov napisati to kar msilim in vse kar sem na tem forumu napisal je plod praktične izkušnje.
Z audiem se aktivno ukvarjam kakih 35 let, izhajam pa tudi iz audiofilske družine, če lahko tako rečem, tako da je s tem hobijem povezano moje celo življenje. Doma smo vedno imeli raznorazne komponente, naročeni smo bili na najmanj dve audio reviji, pa kup raznih knjig, saj sva se z očetom ukvarjala tudi z izdelavo zvočnikov. Pa tudi kakšen bolj preprost ojačevalec sva naredila sama. Poklicno sem v glasbeni industriji od leta 88, s profesionalnim audiem pa imam tudi več kot dvajset let izkušenj. In to konkretnega dela z aparaturami, pa tudi načrtovanjem in postavljanjem in vzdževanjem zvočnih sistemov v klubih in drugih prostorih. Od elaborata, raznih izračunov do končne izpeljave, vključno z akustiko. Tako da kar se tega tiče nisem ravno neizobražen in brez izkušenj. Če kaj hodiš ven po klubih, je zelo velika verjetnost da ti je glasbo reproduciral sistem, ki sem ga načrtoval, izbral in postavil jaz.
Zato audio zame ni samo hobi ampak mislim da to ni tako pomembno. Da audiofil pride do pravega sistema in ga zna tudi pravilno uporabiti pač ni potrebna formalna izobrazba.
Med recezenti v raznih revijah, jih je zelo malo takšnih, ki imajo formalno elektrotehniško izobrazbo. Pa tudi med konstruktorji to ni ravno pravilo, nekateri so bili prej pravniki, drugi računovodje ali pa slikarji ipd. Je pa audio tudi izrazito multidisciplinaren, tako da celovite izobrazbe nima skorajda nihče. Nekdo ki zna narediti vrhunske zvočnike, mogoče nima pojma kako narediti kvaliteten ojačevalec in obratno. Vrhunski sistem pa si lahko postavi audiofil, ki o konstrukciji aparatur nima nobenega pojma. Po drugi strani pa ima lahko še tako izbražen inženir, ki naj bi vedel o tem domala vse, doma sistem ki je popolnoma neposlušljiv.
Audiofili moramo znati oceniti kvaliteto zvoka in pravilno uporabljati audio opremo, kako je narejena pa nam v glavnem niti ni treba vedeti. Saj tudi elektroinženirji ne vedo kako so narejeni vsi elementi, ki jih uporabljajo. Mislim, da formalna izobrazba tu res ni potrebna, veljajo pa izkušnje in pravilen pristop. Tako da lahko nevtralno komponento spoznaš, ne da bi vedel kako je narejena. To je predvsem stvar pravilne subjektivne slušne ocene, kakšni pa morajo biti neki konkretni podatki za nevtralnost pa ne vem če sploh kdo ve. Povezava med objektivno merljivimi podatki in subjektivno oceno ni kar tako enoznačna in tu zaenkrat nekega širokega konsenza še ni. Mimogrede pa še to, transparentnost in nevtralnost nista eno in isto – o tem govori tudi Tommy The Cat na zgornjem linku.
Zate in za ProJeta ne vem koliko vesta o audiu, težko je kar takole soditi po tem kar pišemo po forumih. Zame je preizkus znanja o audiu ni formalna izobrazba ali to kar pišemo po forumih ali kaj podobnega, temveč praktična sposobnost sestaviti kvaliteten sistem. Mislim, da je to bistvo našega hobija. Če bi namesto da debatiramo o audio lahko prek foruma slišali tudi naše sisteme, potem bi bile stvari bolj jasne. Mislim da je to edino kar na koncu reš šteje.
V pol ure poslušanja ti lahko veliko bolj natančno in konkretno prikažem kaj je to nevtralna reprodukcija, kot pa skozi vse razprave o subatomskem nivoju in podbnih jajcih. Nevtralnost zame ni nek abstrakten koncept, temveč predvsem realna kvaliteta audio sistema ki jo lahko slišim. |
-> HIGH-END AUDIO |
| Stran 8 od 10 |
