akacjan
Pridružen/-a: Tor Maj 2010 19:39 Prispevkov: 215 Kraj: Ljubljana
Objavljeno: Pet Apr 14, 2023 11:11 Naslov sporočila: |
Sem bil zraven, ko je Franc snel jermen s pogona. Razlika je bila naravnost šokantna...Izgledalo je takole : na roke je porinil krožni, da se je vrtel malo hitreje ( po stroboskopu ) in poslušali smo CEL počasni stavek ene simfonije, ne spomnim se katere, po moje je bila iz klasicizma, ker ni bil zelo dolg. Po koncu je bila razlika v intonaciji EN sam ton !!!!!
E pa sad..... |
Objavljeno: Pet Apr 14, 2023 11:49 Naslov sporočila: |
Z zanimanjem berem to vašo debato. Vidim, da je veliko faktorjev, ki vplivajo na vernost reprodukcije z vinilk. Ne želim motiti te debate, ker o gramofonih ne vem veliko. Danes sem malo prebiral razne članke na spletu in sem zasledeil zame zanimiv tekst na temo problematike branja zapisa iz LP, glede na to kako je bil prvotno zapisan. Zanima me vaš komentar.
"The basic issue is the linear speed of the groove modulation — the speed of the vinyl passing under the stylus — which becomes much slower for the inner cuts compared with the outer grooves. This means that the recorded wavelengths are correspondingly much shorter and the slope angles are much greater for the inner grooves compared with the outer ones, so the pickup stylus has a much harder time trying to follow the groove.
The problem is worse with higher recorded volumes and greater amounts of high-frequency energy, so cutting engineers tend to prefer placing quieter songs, with moderate bass and lower HF energy towards the centre of the disc — or just restrict the playing time so that the grooves don't have to get too close to the centre.
Then there is the vinyl itself. The recorded wavelengths for high frequencies at the inner grooves approach the grain size of the vinyl substrate, particularly if the disc is made with cheap recycled vinyl, so that also creates distortion problems because the vinyl doesn't actually store the required waveforms properly.
Next is the issue of cartridge/stylus alignment errors, both horizontally and vertically. Records are cut with a parallel tracking system that keeps the cutting stylus perfectly tangential to the circumference of the groove, but the record is replayed with a pivoted arm system. As a result, the stylus can only ever achieve the correct angle at two specific points across the surface of the disc. If set up well, with a 10-inch (or longer) tone arm, the tracking error can be reduced to about ±1 degree across the whole disc, but often it is much, much greater than that because of improper alignment and the use of shorter tone arms.The tracking errors are often more evident on the inner grooves.
There are a lot of different cartridge alignment protocols designed with different sets of compromises, such as trying to improve inner-groove tracking at the expense of outer grooves, where the higher linear speed makes the errors less audible. This is all part of the 'black magic' art of vinyl nirvana... but basically it's trying to put a 'Superman' sticking-plaster on a severed limb: the format is inherently 'broken'!
'Tracing simulation' may also be an issue. A lot of vinyl records were (and are) cut with tracing simulation, which is a form of 'pre-distortion'. The idea is to change the groove slope to compensate for the inevitable tracing distortion that's inherent in the stylus size and shape. In this way, the tracing simulation groove-shape modification counteracts the physical tracing distortion and, ideally, they'll cancel each other out, leaving clean, undistorted music. But there's no standard stylus shape, and if the disc is replayed with a different stylus size, the tracing simulation and distortion won't cancel and you'll be left with more distortion than otherwise!" _________________ "Whenever we find connoisseurship operating within science or technology we may assume it persists only because it has not been possible to replace it by a measurable grading." Michael Polanyi |
Bwaze
Objavljeno: Pet Apr 14, 2023 12:17 Naslov sporočila: |
| ambasador je napisal/a: |
Wow&Flutter je v grafičnem prikazu čačka, ki ponazarja naglo spreminjanje hitrosti. V ozkih mejah a slišno. Pomeni da krožnik na mikro ravni stalno pospešuje in pojema, drhti.
Mi je osebno povedal, da ko so sneli jermen med igranjem se je slišalo relax v zvoku. Zame je bila to širitev obzorja, da niti 50kg ni definitivna rešitev, ker sem imel izkušnjo samo do 9kg.
Ni stvar verovanja, so fakti. Je težko preklopiti miselnost, kot naprimer o togosti skale: grem na pomol k največji skali valobrana in nanjo naslonim glasbeno vilico, ki jo poprej zaniham. Skala močno ojači 'zujanje'. Za ne verjet, probajte. |
No, tudi zid (iz zidakov, ne kartonast ameriški) v hiši v nihanje spravi že zvok.
V tem primeru jaz razumem le, da se je na krožnik prenehalo prenašati trzanje motorja (cogging). Motorji, ki jih povečini uporabljajo izdelovalci gramofonov, so za namen čimbolj gladkega vrtenja brez tresljajev in trzanja dokaj neprimerni - malo polov, velike spremembe v navoru v enem obratu - in niti ni važno, a gre za AC ali DC motorje. Ampak to pač je na trgu. Praktično noben izdelovalec še tako ekskluzivnih in dragih gramofonov si zdaj ne more privoščiti razvoja novega elektromotorja samo zanj - je lažje drejati nek masiven stolp, v katerega potem skrijemo motor z zasnovo, starejšo od 50 let... Izredno masivni krožniki so torej tudi posledica poskušanja izenačevanja vrtenja motorja. _________________ Pezzer Ritter Wenne Knecht! |
jože
Objavljeno: Pet Apr 14, 2023 14:44 Naslov sporočila: |
Ko tole prebiram, se mi vsiljuje vprašanje, s katerim oziroma s kakšnim pogonom so posnete matrice za izdelavo plošč. Če prav vem, so rezalniki za matrice tudi gnani z motorjem, ki je podvržen nihanju hitrosti vrtenja. Kako, da tega nihče ne obravnava, kot da je vsemu kriv samo "domači" gramofon, ali ima samo gramofon Wow and Flutter, ali ni nekaj tega Wow and Flutter-ja že posnetega??????
Glede motorjev za gramofone.
Za dober rezultat, nizek Wow and Flutter pri gramofonu je še kako pomembno, kakšen pogon ima, opažam, da dosegajo najboljši rezultat Wow and Flutter-ja z sinhronskimi motorji, ki so gnani z elektronskim generatorjem frekvence. ti gramofoni nimajo ne vem kako pretirano težkega krožnika in je pri njih Wow and Flutter brez težav 0,05% ali boljši. Pri gramofonih kjer je sinhronski motor napajan direktno iz omrežne napetosti, pa ne dosegajo tako dobrih rezultatov zaradi popačenosti mrežne napetosti!
DD pogoni imajo druge prednosti, vendar le s težavo lovijo Wow and Flutter kot ga imajo gramofoni s sinhronskimi motorji.
Potem so tu še DC motorji v povezavi z taho generatorjem, ki ne dosegajo tako dobrih rezultatov kot sinhronski motorji. |
Bwaze
Objavljeno: Pet Apr 14, 2023 15:22 Naslov sporočila: |
| jože je napisal/a: | | Ko tole prebiram, se mi vsiljuje vprašanje, s katerim oziroma s kakšnim pogonom so posnete matrice za izdelavo plošč. Če prav vem, so rezalniki za matrice tudi gnani z motorjem, ki je podvržen nihanju hitrosti vrtenja. Kako, da tega nihče ne obravnava, kot da je vsemu kriv samo "domači" gramofon, ali ima samo gramofon Wow and Flutter, ali ni nekaj tega Wow and Flutter-ja že posnetega?????? |
Stružnice za vrezovanje laka (ali še posebej za vrezovanje na kovino, Direct Metal Master) so dobesedno to, stružnice. Masivne, mehko obešene (za izolacijo pred zunanjimi tresljaji), z velikimi močnimi motorji, ki se vrtijo z velikimi obrati in je potem to togo zreducirano na 33 1/3 ali 45 RPM - ali polovico tega, za half speed mastering. In ja, imajo že v štartu specificiran wow & flutter, in to je potem vrezano.
Na Pink fish media forumu, kjer so opravljali grafične analize, so kmalu ugotovili, da ima izbrana testna plošča, Analogue Productions - The Ultimate Analogue Test LP (180 gram) v bistvu serijsko napako, pri vseh ploščah na enem mestu na obrat frekvenca 3150 Hz poskoči - na vseh izmerjenih gramofonih. In pa seveda wow, ki se je kazal kot enak kljub različnim tipom gramofonov. Testna plošča Dr. Feickert Adjust+ je baje še slabša, pa je bila del dragega kompleta za analiziranje.
"Pretty much why I gave up caring. The test lp was cut by the best process and people going. No music lp is going to be any better. Once the TT is as good as the lathe, job done."
Primer prikaza odstopanja na Dr. Feickert Adjust+ :
Izgleda krompir, ampak to je prikazano pretirano odstopanje, maksimum je tu ok. 0.88%, povprečje (kar običajno podajo) pa veliko nižje. _________________ Pezzer Ritter Wenne Knecht! |
Objavljeno: Čet Apr 27, 2023 09:51 Naslov sporočila: |
| benma je napisal/a: | Z zanimanjem berem to vašo debato. Vidim, da je veliko faktorjev, ki vplivajo na vernost reprodukcije z vinilk. Ne želim motiti te debate, ker o gramofonih ne vem veliko. Danes sem malo prebiral razne članke na spletu in sem zasledeil zame zanimiv tekst na temo problematike branja zapisa iz LP, glede na to kako je bil prvotno zapisan. Zanima me vaš komentar.
"The basic issue is
more distortion than otherwise!" |
Tudi moj komentar bo irilevanten - kot je citirani člančič .
Poleg netočnosti (naprimer modulacija ki se bliža zrnatosti vinila - kvadrofonija ima zapis do 40.000Hz, mimogrede..) je tudi nekaj korektnih navedb. Itak da ni celovito obravnaval problematike (izpuščene najpomembnejše!).
Zapis se 'zgošča' proti centru plošče in to da je glavni problem. V praksi ponavadi res je - a niti približno glavni - in niti ne zaradi tega, ampak ker kratke ročice distorzirajo. Zato obstajajo dolge ročice in tudi drugačne geometrije kratkih (včasih so ravno zaradi tega nekateri japonci imeli geometrijo z eno samo nulto točko tangencialnosti bližje izteku brazde).
Doma imam tangencialno ročico in tisto prvo kar se opazi proti izteku brazde je, da je manj šuma vsled nižje obodne hitrosti (nižji šum drsenja igle) in se po svoje celo bolje sliši proti koncu.
Resolucije proti izteku brazde ne vidim kot problem, čeprav je dejstvo da se modulacija zgosti.
Za primerjavo - resolucija začetka vs izteka brazde je meni neslišna razlika. Veliko bolj opazna je razlika med konično vs eliptično iglo. Pa že konična je zakon za jazz, rock in pop glasbo, jo 'zmanjka' a samo v primerjavi z eliptično iglo in samo za zahtevne pasaže klasike in orkestralne glasbe.
Razlika v resoluciji igel je ranga CD vs SACD, tako da imajo tudi digitalisti občutek o čem teče beseda. In kot sem dosedaj zaznal od digitalistov, večina tega ne razloči, ergo.. nekaterim je dovolj že MP3.
Članek navaja glasne pasaže in visoke frekvence (velike modulacije) kot težavo na izteku brazde - večina pompozne klasike se zaključi na koncu LP-ja. Poslušajte si zaključek - zadnje 3 minute - 5. Beethovnove na dobrem gramofonu, je vsega od masivnih violin, trobil, tolkal - da se ti ježi koža vsakič nanovo. Če je to velik problem, dobrodošel, hehe.
@jože
https://www.psaudio.com/blogs/copper/around-the-world-in-80-lathes-part-23
Tukaj so podatki o sinhronih motorjih Lyrec/Neumann rezalcev - direkt drive s sinhronimi motorji. In to kakšnimi!
Za evropo 180 polni direct drive za rezanje na 33,33 vrtljajih. Za ZDA 216 polov (60Hz). Za različne obrate (in frekvence) različni motorji.
Zanimivo - 45 plošče na nominalno istih obratih niso bile rezane tako - ameriške 45 singlce na točnih obratih, evropske 45 singlce pa so bile rezane na 45,11obratih. Ker se poli na motorjih niso izšli.
Ne vem pa danes, kadar izdajo nekoč 33,33 LP na 45 obratih - na čem so rezane matrice LP - jev. Na starih mašinah? ali na novih in kateri obrati veljajo? Bi šel stavit, da so američani brez težav ostali na 45, vprašanje so evropske izdaje - 45 ali 45,11? Če imaš stroboskop, nujno kaže 45,11 obrate kot točne. _________________ Carpe Diem |
jože
Objavljeno: Sob Apr 29, 2023 11:36 Naslov sporočila: |
| ambasador je napisal/a: | @jože
Ne vem pa danes, kadar izdajo nekoč 33,33 LP na 45 obratih - na čem so rezane matrice LP - jev. Na starih mašinah? ali na novih in kateri obrati veljajo? Bi šel stavit, da so američani brez težav ostali na 45, vprašanje so evropske izdaje - 45 ali 45,11? Če imaš stroboskop, nujno kaže 45,11 obrate kot točne. |
Zanimivo je pogledat te mašine za izdelavo LP-jev. Kakorkoli so se trudili s sinhronskimi motorji, ki so skrbeli za točno vrtenje pri rezanju matrice, so bili ti motorji po vsej verjetnosti napajani iz omrežne napetosti, ki pa je prav tako bila lahko motena z nenadnimi vklopi in izklopi močnih porabnikov, ki so vplivali na obliko sinusne napetosti, posledično temu tudi nemirnosti vrtenja krožnika rezalne mize. Poleg tega je posnetek potekal iz magnetofona, ki tudi nima 100%-tne mirnosti v predvajanju, tako da so to bili kar hudi izzivi za takratno tehnologijo.
Glede stroboskopa, nisem tako zelo prepričan, da bo stroboskop pokazal 45.11 vrtljajev pri vrtenju, saj je tu število črtic na krožniku gramofona ni povezano s polovimi pari, tako kot je pri sinhronskem motorju. Črtic je lahko poljubno število.
Današnja tehnologija omogoča frekvenčne pretvornike za pogon motorjev, s katerimi na desetinko natančno lahko nastaviš vrtljaje motorja in s tem ni več vprašanje točnosti pri hitrosti 45. |
sg
Pridružen/-a: Pon Maj 2013 10:39 Prispevkov: 73 Kraj: Lj
Objavljeno: Ned Apr 30, 2023 02:19 Naslov sporočila: |
[quote="jože"] | ambasador je napisal/a: | @jože
Črtic ne more biti poljubno število - treba bi jih bilo 133,33.
Najbližje celo število 133 navidez mirujočih črtic pa res pomeni 45,11 obratov na minuto. |
jože
Objavljeno: Ned Apr 30, 2023 09:26 Naslov sporočila: |
[quote="sg"] | jože je napisal/a: | | ambasador je napisal/a: | @jože
Hvala za korekturo, sem narobe razmišljal.  |
Objavljeno: Ned Apr 30, 2023 20:01 Naslov sporočila: |
Če uporabljaš frekvenco omrežja za lučko stroboskopa (kar uporabljajo vsi že od nekdaj, ker zadošča kartonček stroboskopa in namizna lučka, seveda ne LED ampak ta stara) je število črtic stroboskopa samo eno. Lučko vidimo svetiti, v resnici pa ona utripa (se prižiga in ugaša z z izmenično napetostjo) samo da mi zaradi 'vztrajnosti' očesa tega ne zaznamo tako.
Lučka torej utripa na vsaki polperiodi frekvence enkrat (= 100x na sekundo za 50Hz), 45,11 obratov/minuto pomeni 1,33 obrata na sekundo. 1,33 obrata x 100 utripov = 133 črtic da se utripi ujemajo s črticami.
Med utripi lučke se stroboskop premakne za eno črtico. Če se to ujema, so obrati točni in črtice mirujejo. Če prihaja do zaostajanja ali prehitevanja obratov, se to vidi kot lezenje črtic nazaj ali naprej.
Znan je primer iz western filmov, kjer vidimo kočijo, kateri se vrtijo kolesa nazaj. Stvar je povezana s filmsko tehnologijo (24 sličic na sekundo, torej 24 krat pomežikne) in vrtljaji koles povezanimi s številom prečk koles (črtic) - po istem principu stroboskopa pri gramofonih. Preskakovanja iz ene sličice na drugo ne zaznamo, a izda ga stoboskopski efekt - tega pa lepo vidimo, se prav imponira.
Isto je v glasbi v povezavi s flutterjem (drhtenjem hitrosti). Na določeni glasbi ne bomo slišali težav, se pa vedno najdejo take plošče, ki ti v fris vržejo problem. Se spomnim primera hifija visoke klase, vse lepo gramofon obdela, dokler niso violine prešle v odločen staccato - se je slišalo kot zbor brzostrelk, noro.
Flutterja se ne da skriti. Spreminja dogajanje po spektru. Določena področja zakriva (pogosto je žrtev globoki bas) določena siromaši, oskubi (srednje tone ponavadi), določena pa poudarja (si zmišljuje, dodaja, običajno srednji visoki da vreščijo).
Zanimivo, iste učinke ima jitter v digitalni domeni, se tudi podobno odziva. Pa se hitro ve ali imaš problem jitterja. Prve žrtve so globoki bas (pedali na orglah), ki ponikne - in dinamika - je ploščato, nezanimivo.
Iz stroboskopskega učinka se lahko naučimo tudi, da lahko ritmi zvenijo hitreje kot bi morali in pa tudi počasneje. Iz gramofonske zgodovine so bili znani primeri ko je kljub točnim obratom flutter dajal vtis kot da glasba hiti. In nasprotno, eni so zgradili imidž na počasi odvijajoči se glasbi.
Pri CD-ju se spomin podobnega učinka z Decca kolekcijo starih posnetkov na Onkyo playerju. Mater, kot da je dirigent Dorati na štoparico.. verjetno je šlo za kombinirano akcijo med flutterjem posnetka in jitterjem playerja. Neposlušljivo.
Če povežem z vprašanjem kako se pa flutter rezalca plošče odraža v reprodukciji - ne vem. Sigurno se, a še nisem pogruntal. Do takrat se mi zdi najbolj primerno poganjati gramofon z istim principom - sinhronim motorjem. Ne glede na število polov, se preko prenosa pride vedno na isto: 180 korakov na obrat. To se potem z vztrajnikom gladi a spodaj spodaj, prikrito, prikrito, je isti karakter od rezalca. Če drugo ne, se ne vnaša še nekaj tretjega. _________________ Carpe Diem |
