ikovacic
Pridružen/-a: Tor Okt 2009 14:27 Prispevkov: 5 Kraj: VOJNIK
Objavljeno: Sob Mar 09, 2013 00:29 Naslov sporočila: Težave z popcorn a-400 |
| Potrebujem pomoč pri namestitvi notranjega diska v pocorn a-400. Po namestitvi v ohišje mi ga popcorn nikakor ne zazna in tudi pri povezavi z računalnikom imam enake probleme. Hard disk je WD 3 TB z oznako 30ezrx. Ali je imel kdo podobne probleme in kako jih je rešil. Poleg tega mi pri predvajanju filmov v BD25 ne omogoča zvoka DTS, prosim za rešitve, če jih je kdo že uspel implementirati v predvajalnik. Moram reči, da sem kar razočaran z navodili, ki jih je proizvajalec objavil na svoji strani. |
Telefon: 041-425-694 |
igorb
Pridružen/-a: Sre Sep 2010 14:22 Prispevkov: 10 Kraj: štajerska
Objavljeno: Sob Mar 09, 2013 00:51 Naslov sporočila: |
Odgovor boš našel na straneh www.avforums.com. Wd diski znajo biti težavni. Mogoče ti ta odgovor iz avforuma pomaga. Lp.
Originally Posted by corban
So my unit arrived over the weekend and had my first play around with it tonight. The mounting system for the HDD is at best basic but in all honest I dont like it at all. That said I found the remote to be a lot better than I expected.
I have a couple of questions I hope someone can answer for me. Firstly I cannot get my 3TB drive to work/be recognized in this, is this a known issue or does it not support 3TB drives ?.
Secondly, playing some mkvs and testing out it took a while but did get DTS 5.1 but couldn't get DTS-HD tested multiple files which all have DTS-HD. I was under the impression it did play DTS-HD so any help would be great.
Am now going to try with NMJ and have a play, thanks for any help provided.
First thing first is it a WD 3tb drive? If so was it one of them preformatted ones? If so you need to stick it in a computer and wipe out all the partitions on it and make it a raw drive then format it normal for ntfs. then stick it in the pch it will see it. the preformatted wd drives have some strange things on it that make it compatible with winxp and it screws up a pch,
2. make sure all audio under setup is set to passthrough, and dts-hd should work fine, You are playing to an avr that can handle dts-hd correct? |
taddeo
Pridružen/-a: Pon Sep 2012 14:32 Prispevkov: 67 Kraj: MARIBOR
Objavljeno: Sob Mar 09, 2013 10:40 Naslov sporočila: |
Na tem linku http://www.networkedmediatank.com/ greš pod temo A400 in malo pregledaš...ali pa objaviš tvoj problem.Tukaj imaš starejše in bolj novejše firmware za A400 http://www.popcornhour.com/download/A400/firmware-A400.html Jaz imam forum relase (1 marec).Gledam samo filme BD50 in BD25 in redko MKV deluje pa brez problema.Nastavi v meniju Pch audio DTS na passtrought ,če že nimaš...downloadaj si Partition Magic ali Easus in temu podobn program..tam ti bo prepoznalo disk na računalniku in ga formatiraj v formatu ext3.Slučajno ,če ti prepozna računalnik hdd brez tega programa..klik z desnim gumbom miške-formatiraj... _________________ FORZA JUVENTUS! |
knap
Objavljeno: Sob Mar 09, 2013 19:21 Naslov sporočila: |
ikovacic
zdravo, jaz imam ta disk v a400, je formatiran v ntfs (največja particija, cca 2.67 TB - za filme....),druga particija je v ext3 na kateri so naloženi nmt apps
sedaj točno ne razumem tvojega problema, praviš da disk ni viden, da pa predvajaš bd25 filme, od kod?, preko mreže? torej imaš naložene nmt apps?
torej malo bolj podrobno povej, da ti lahko pomagam
knap
ikovacic
Objavljeno: Ned Mar 10, 2013 11:17 Naslov sporočila: |
| Hvala za pomoč pri nameščanju diska v A-400. Po priloženih linkih sem na forumih zazanal da imajo tudi drugi podobne probleme. Verjetno je problem v formatiranju diska, kot je napisal knap ( hvala ti za sugestijo ), kar se pa tiče predvajanja BD25 filmov, pa jih poganjam iz zunanjega diska. Sedaj sem nastavil zvok v A-400 na passthrugh, vendar še nisem probal ali deluje, sem mal na tesnem z časom, pa še otroci so okupirali TV z risankami, tako da bom probleme probal reševati v naslednjih dneh. Poročam ali so se zadeve uredile. Hvala vam za pomoč.[/b] |
knap
Objavljeno: Ned Mar 10, 2013 19:35 Naslov sporočila: |
torej imaš dve možnosti datotečnega sistema, ext3 in pa ntfs
ext3 je linux zadeva (vsi popcorni tečejo na linuxu), to je bila moja prva izbira, saj bi naj predvalnik bolj hitro deloval z ext3
žal sem imel velike probleme in nikakor nisem mogel skopirat 3tb filmov preko usb slave povezave na ext3 particijo, vedno sem dobil BSOD in pri tem izgubil vse podatke, torej sem bil spet na začetku
ko si namestiš nmt apps se ti disk avtomatsko formatira v ext3, seveda se ti z nmt apps naloži tudi samba server...., ki je potreben da a400 povežeš z pc-jem preko mrežne povezave, vendar pa je kopiranje preko te povezave izredno počasno
veliko hitrejša je povezava preko usb slave 3.0
problem pa je v tem da windows ne prepoznajo ext3 zato moraš namestit ta program:
http://www.networkedmediatank.com/wiki/index.php/USB_Slave
http://www.ext2fsd.com/
ki pa na mojem pc-ju ni bil stabilen....
zato mi ni preostalo drugega kot da data particijo formatiram v ntfs, kopiranje na ntfs je potekalo hitro in brez težav
še nekaj, pred vsem zgoraj napisanim sem tudi naloži:
A-300 and A-400 USB Slave fix for 2TB and larger hard drive with GPT
http://www.networkedmediatank.com/showthread.php?tid=65192
kumer
Objavljeno: Tor Maj 28, 2013 08:56 Naslov sporočila: |
novi testi PCH-A400:
http://www.pocket-lint.com/review/121090-popcorn-hour-a-400-review
| Citiram: |
There are some things the Popcorn Hour does incredibly well - for example, picture quality. It's very good here and neglected on other media players and especially on laptops and the like. Plus, you get the power needed to play 3D or 1080p video flawlessly. Many laptops can still choke on high bitrate HD video. Oh, and let's not forget the fact that it's far more reliable than a PC-based solution.
The problems still exist though, Wi-Fi is an optional extra. Although it's not expensive to add, we'd really expect to see it built in by now on a device that competes in an arena where almost everything is wireless. At £270, it's also a little bit expensive considering a lot of media players are less than £100 now, and much of this functionality exists in smart TVs.
With all that said though, the A-400 is still the gold standard for media players. It's picture and sound quality will likely not be matched on any TV or other device. It might seem limited, in terms of modern media players, but the focus is still on picture quality more than it is on anything else, and there are more features here - like 3D and ripped Blu-ray playback - than you'd get on most players.
________________________________________
For
Picture quality, fantastic build quality, plays things other players can't, loads of networking options, fantastic connectivity, can take a 3.5-inch hard drive for media storage
Against
Quite expensive, have to provide your own internal storage, online services still not that compelling
http://www.allmytech.pk/forums/viewtopic.php?t=28&p=86
| Citiram: |
CONCLUSION
Popcorn Hour A400 is the latest player from Syabas and it offers exciting new features such as the built-in jukebox for movies, music and images, 3D support, tablet controls, an App Store, and Airplay streaming from Apple devices.
A400 is also a player for your local media content library and it can store a 3 TB hard drive if you don’t want to use a network hard drive. The built-in jukebox is simple in use and when combined with a tablet you have a pretty good setup for your entire family. You can even do it without ever having to touch the old-school infrared remote again, and the tablet allows you to start music without having to turn on the TV for a navigation interface. The entire interface is moved to the tablet screen – and that is a good thing.
However, first and foremost we miss access to popular streaming services from Netflix, HBO, Hulu Plus and so forth. The online app store has a pretty disappointing selection of apps and the apps that are available are slow or just old.
We also experienced some issues with subtitles and audio, and the massive stream of software updates tells us that Syabas has a lot to take care of before we can consider this a fully-baked bread. We simply experienced too many bugs and shortcoming during the review. The A-400 surely has potential but if we were in charge we would probably wait 3-6 months before releasing the product to the public. Software updates are nice if they add new features but not if they are released only to fix an endless batch of bugs..
kumer
kumer
kumer
Objavljeno: Pet Sep 20, 2013 14:53 Naslov sporočila: |
in potem vse tiho je bilo
ali trg večpredstavnih podaljškov umira?
se mi zdi, da ni ravno nekega velikega napredka, novih modelov itd.... to da pametne tv vzamejo del uporabnikov je jasno, samo za poslušanje 5.1, 7.1 zvoka preko av receiverja je še vedno potreben blu ray predvajalnik ali VP.
No, malo z zamudo predstavljam:
Popcorn Hour A-410 PRO
VP za audiofile
| Citiram: |
Penang, Malaysia; September 4, 2013 – Cloud Media Sdn. Bhd, a leading global manufacturer of digital entertainment solutions, is excited to announce the latest addition to the Popcorn Hour product line, the Popcorn Hour A-410 PRO.
The Popcorn Hour A-410 PRO utilizes the Sigma Design’s Dual Core 800Mhz SMP 8911 chipset and combines the outstanding video capabilities with a high-end, all-analog preamp-processor. The 7.1 Audio output makes the product an ideal choice for home cinema enthusiasts and the 2.0 XLR balanced audio connectivity integrates perfectly into sophisticated home entertainment environments.
With a 24bit / 192khz onboard audiophile DAC the Popcorn Hour A-410 PRO can play back various audio file formats including the advanced DSD container. A dual power supply with a toroidal transformer for the audio preamplifier underlines the achievable sound quality.
On the video side a studio-quality VXP® processing is included, offering fully adaptive deinterlacing, adaptive Film Cadence Detection and adaptive contrast enhancement.
With support for Blu-ray 3D-Video, Full-HD video, several audio and photo codec’s and web content, users can experience their digital media how they want. The Cloud Media Apps Market, containing over 100 free and premium TV and audio apps, gives users a broad selection of additional entertainment via the web. Especially the latest premium app of the music service Qobuz - the world's leading platform for lossless streaming and high definition music download - offers a huge catalogue of all music styles in true CD and also in Studio Masters quality. So it is a perfect addition to the Popcorn Hour A-410 PRO. Today Qobuz is already available in France, Belgium, Switzerland, Luxembourg and additionally planned to open November 1st in Germany, Austria, The Netherlands, UK and Ireland.
The Popcorn Hour A-410 PRO will include some more exciting features to enhance the media playback experience. In addition to video metadata and posters, users can also download subtitles directly from the web without having to use a PC and select 1 of 22 different languages they prefer the information and subtitles to be downloaded in.
The NMJ navigator provides an even more natural remote control via a 2nd screen iPad® or Android® companion opportunity.
The Popcorn Hour A-410 PRO can be upgraded with an internal 2.5 and a 3.5-inch hard disk which can be mounted in a HDD quick dock, turning the device into a network attached storage device. Users also have the option of using the built in 10/100/1000mbs Gigabit Ethernet port or they can purchase a Wireless N Wi-Fi dongle. An SD card reader, USB 2.0 ports, and an eSATA interface are also included for external storage.
“With Popcorn Hour A-410 PRO we combine the latest audio with the latest video technology and open a new category of high end media players. This combination of advanced quality and ease of use makes a perfect package for our customers” said Manfred Karl, VP Sales EMEA region.
The MSRP for the Popcorn Hour A-410 PRO will be below €1,000 in the European Community (including VAT). The first products are planned to be shipped in Q4 2013.
About Cloud Media
Cloud Media and their award winning Popcorn Hour and FreeOTT brands set the bar for networked digital entertainment devices. Their innovative products enable consumers to enjoy a wide assortment of content including home videos, photos, music and online movies. With access to 100+ apps at the Cloud Media Apps Market, users can also enjoy all the latest content on popular services such as YouTube, Facebook, Twitter, TuneIn, Qobuz and much more. Expanding into the rapidly growing market of on-line media streaming, they also offer an affordable OTT solution with their apps market. Cloud Media and their continually expanding network of content providers offer also exceptional value for ISPs and operators looking for a low cost or subsidy based delivery platform. With offices in the U.S., China, Malaysia, Hong Kong and Germany they understand and cater to a global audience. For more information, please visit http://www.CloudMedia.com.
ne vem, kaj se je zgodilo z firmo syabas, ki je stala za popcorni...., očitno jo je pojedla neka malezijska firma...
kumer
taddeo
Objavljeno: Pon Sep 23, 2013 14:38 Naslov sporočila: |
Jaz ostajam zvest PCH A400...in sem z njim zelo zadovoljen.Edino kaj me vleče je novo ohišje za A400 (A400 M ),ker vsako leto ,da kupim nov model se mi finančno več ne izide  _________________ FORZA JUVENTUS! |
kumer
Pekl
Pridružen/-a: Sob Okt 2013 9:09 Prispevkov: 2 Kraj: Nova Gorica
Objavljeno: Sob Okt 05, 2013 09:12 Naslov sporočila: |
Pozdravljen,
Kako si pa na NMT-ju uspel ustvariti 2 particiji? Ali je to možno ali si si pomagal kako drugače?
Kaj ti zaradi NTFS particije sedaj NMT dela bolj počasi?
Hvala
lp Pekl
| knap je napisal/a: | torej imaš dve možnosti datotečnega sistema, ext3 in pa ntfs
